Column help
You can get help for any workspace column by positioning your cursor in the field with the column name and pressing F1. A menu is displayed containing a description of the attribute for the data that is being displayed. A question mark (?) entered in column 1 of a summary type subpanel also displays help for the column. For an example, see Help for column headings.
