Preparing the environment for automated tasks
The deployment planning tools and
the topologies that you create in them can help you model and plan
automated deployment tasks. The first step in running these tasks
is to set up an automation environment and connect to the environment.
Before you begin
These steps are required for deployment automation with IBM® Rational® Build Forge® but not for deployment automation with Apache Ant.
Deployment automation requires the IBM Rational Software Architect Extension for Deployment Automation Planning.
About this task
Procedure
- Install the Rational Build Forge client. See Installing the Rational Build Forge client.
- Connect the client to Rational Build Forge. See Connecting the client to Rational Build Forge.
- Configure the automation environment to run tasks from the deployment planning tools. See Configuring the automation environment.
