vce
Used by convention as the top element, processed the same way schema.x.element.scope is processed.
Attributes
  • id (NMToken) - A unique id for the current Vivisimo object. When debugging, the id is used to create a directory in debug-dir where debugging information will be stored. Usage: Internal
  • input-ids (NMTokens) - The ids of all the object inputted. Usage: Read-only
  • projects (NMTokens) - List of all the projects loaded in this object. Usage: Internal
  • merge-count (NMToken) - Usage: Internal
  • authenticated-user (NMToken) - The name of the authenticated user. Note that a result set bearing this attribute can only be loaded by an object in which the user is authenticated. Usage: Internal
  • execute-acls (Text) - Newline separated list of rights optionally preceded by +/-. Given a current set of rights, a node with this attribute will only be processed if 1/ none of the rights is specified with - 2/ either no positive right (i.e., preceded with + or nothing) is specified or one of the ones specified is part of the current list of rights. Usage: Internal
  • version (Text default: 7.x) - Identifier for the version of the repository being used. During an upgrade to a newer version of Watson Explorer, this number is used to trigger the conversion or importing of repository nodes from the old version to the new one. Usage: Internal
Children
  • Use these in the listed order. The sequence may not repeat.
    • Choose any number of these in any order.
      • set-var: (Zero or more) - Set a variable
      • declare: (Zero or more) - Variable declaration
      • if-var: (Zero or more) - Conditional processing (test a variable value)
      • if: (Zero or more) - Conditional processing (test an XPath expression)
      • while: (Zero or more) - Conditional repeated processing (test an XPath expression)
      • for-each: (Zero or more) - Repeated processing of a nodeset
      • choose: (Zero or more) - Selective processing
      • scope: (Zero or more) - Variable scope
      • function: (Zero or more) - Function definition
      • meta: (Exactly 1) - Specify the "query words" for clustering optimizitation
      • tag: (Exactly 1) - Customizes the handling of HTML tags
      • option: (Exactly 1) - Specify Watson Explorer options
      • form: (Zero or more) - A form specifies how to convert a set of CGI parameters, i.e, a set of name value pairs, into a structured (Boolean) query and vice versa.
      • submit: (Zero or more) - Submits the current structured query using the underlying form(s) (query to CGI conversion step)
      • query: (Zero or more) - Converts the current set of CGI parameters into a structured query
      • param: (Zero or more) - CGI parameter passed to the Vivisimo object
      • field: (Zero or more) - Query field definition
      • operator: (Zero or more) - Logical operator definition
      • syntax: (Zero or more) - Syntax container
      • parser: (Zero or more) - Parser definition
      • parse: (Zero or more) - Parse data (eventually after fetching it from a URL) into XML
      • process-xsl: (Zero or more) - Process some XSL code
      • source: (Zero or more) - Necessary information to meta-search a remote resource
      • add-sources: (Zero or more) - Process the sources referenced
      • kb: (Zero or more) - Knowledge base container
      • options: (Zero or more) - Global options container (projects)
      • vars: (Zero or more)
      • prototype: (Zero or more) - Prototype of a function or source
      • log: (Zero or more) - Tag in which the log nodes are collected
      • document: (Zero or more) - One document to be clustered (input) or that has been clustered (in tree in the output) or a duplicate (in documents in the output)
      • binning-full: (Zero or more) - Element containing the hierarchy of bins as returned by the Watson Explorer Search Engine, when double-binning is enabled
      • added-source: (Zero or more) - Node containing information about an added source
      • boost: (Zero or more) - Elements contained in this node will be "boosted" to the top of the list of results
      • user: (Exactly 1) - Element containing user information
      • user-authenticate: (Exactly 1) - Authenticate a user in the current object
      • user-create: (Exactly 1) - Create a new user
      • user-modify: (Exactly 1) - Modify a user profile
      • load-user: (Exactly 1) - Element containing user information
    • Choose 0 to 2 of these in any order.
      • documents: (At most 2) - Contains documents to be clustered or documents that have not been put into the tree by the clustering process
      • tree: (At most 2) - Holds the clustered output or, in a state output, the state of the tree
      • list: (At most 2) - Element containing the list of documents currently viewed
