Sentiment analysis attempts to determine whether documents have a positive, negative, or neutral disposition. Watson Explorer Engine Engine supports sentiment analysis via a built-in converter known as the Sentiment Analyzer. The Sentiment Analyzer can only perform sentiment analysis on documents that are in English.
To add the Sentiment Analyzer to the conversion pipeline for a search collection:
After adding the Sentiment Analyzer to the conversion pipeline for a search collection, you can either click OK to accept the default settings in the Sentiment Analyzer or customize its settings, as explained in the next section.
After accepting the default settings for the Sentiment Analyzer or customizing its settings, it will be invoked as part of the conversion pipeline when crawling the seed(s) that are associated with that search collection. When crawling the data sources associated with the seed(s) used in your collection, the Sentiment Analyzer will add a content element whose name attribute is disposition and raw_score to each document that was identified as having a positive, negative, or neutral disposition:
