Projects
Projects let you define sets of options and global variables, allowing you to create, edit, and run multiple Watson Explorer Engine applications in parallel with very different configurations. If you are using the default query-meta CGI script you can switch between projects by setting the v:project CGI parameters to the name of the project.
A project specifies two types of parameters (which are displayed in the same format):
When creating a new project you need to select another project as a base project. This base project will determine the default values of the dependent project. It is therefore possible to create a hierarchy of projects and maintain variations of projects without having redundant configurations.
The core project is the default base project. It contains all of the default option values and the declarations of the variables used by the query-meta CGI script. Some of these parameters and associated values are automatically passed as CGI parameters so that the query-meta project works properly.
The following subsections of this section describe the different types of options used in the software. Variables (as well as options) are documented "inline" in the project section of the Watson Explorer Engine administration tool (just click on the icons).
