System Configuration Dialog Box
The Sterling Gentran:Server® System Configuration dialog box (with the Audit/Notification tab selected) allows you to access the Audit Notification System components you need to configure audit and notification activities.
The Audit Notification System components are:
- Audit Messages
- Notifications
- Operators
- Server settings
Note: This dialog box also allows you to purge the contents of the
Audit Log.
To access the System Configuration dialog box, from the Start menu select Programs > Gentran Server > Gentran Server Configuration. When the system displays the System Configuration dialog box, select the Audit/Notification tab.
The following table describes the parts of the System Configuration dialog box (Audit/Notification tab):
| Part | Function |
| Messages | Accesses the Audit Messages browser to view the
list of audit messages. From this dialog box you can access others
to:
| Notifications | Accesses the Notify dialog box to view the list of notifications defined in the system. From this dialog box you can access others to add, change, and delete notifications. |
| Operators | Accesses the Operators browser to view the list
of operators defined in the system. From this dialog box you can access
others to:
| Server | Accesses the Audit/Notification Server Properties dialog box to configure database and notification server options (such as communications port and MAPI profile), as well as setting service dependencies. You can stop and start the Audit Notification Server from this dialog box. |
| Purge | Deletes the contents of the Audit Log. Note: You
can also purge the Audit Log by using the GDW_Audit_Purge command
in a Process Control session.
