IBM Endpoint Manager, Version 9.2
Creating IBM BigFix Remote Control server installation tasks
With the IBM® BigFix® Remote Control Server Installer Wizard, you can create an installation task to install a remote control server.
About this task
Run the task on a Windows® system or Linux (Red Hat and SUSE) systems to install a fully functional, self-contained IBM BigFix Remote Control server with either of the following component setup:
  • IBM BigFix Remote Control server with WebSphere® Application Server 8.5 Liberty Profile and a Derby database.
  • IBM BigFix Remote Control server with WebSphere Application Server 8.5 Liberty Profile and one of the following databases:
    • IBM DB2® 9.x, 10.1, or 10.5 Workgroup(WSE) and Enterprise Edition(ESE).
    • Oracle 10g or 11g.
    • Microsoft SQL server 2008, 2012, or 2014.
Note:
  1. If you choose the DB2, MS SQL or Oracle database options, you must install the database and create a database instance before you run the server installation task.
  2. If you are using DB2 9.7 GA version, you must upgrade to DB2 9.7 fix pack 1 due to a DB2 issue where NULL values are returned in generated key values.
To access the IBM BigFix Remote Control Server Installer Wizard, complete the following steps:
Procedure
  1. In the IBM BigFix Remote Control navigation tree, select Manage Configurations > IBM BigFix Remote Control Server Installer Wizard.
    Server installer wizard
  2. Set your configuration values.
    Load Settings from Existing Task
    The wizard initially displays server configuration default values that you can change to your own requirements. To load previously saved settings, click Load Settings from Existing Task to display the saved values.
    1. Click Load Settings from Existing Task.
    2. On the Wizard Fixlets screen, select the task.
      Choose a server installation task from the displayed list
    3. Click Load Wizard with Fixlet. The configuration values are loaded into the wizard.
    Reset to default values
    You can use this feature to clear any selections that are made and return the values in the wizard to the default configuration values.
    Create a configuration task
    Select the database and set your database values.
  3. When you set your values, save the installation task by completing step 5.
Feedback
