IBM Control Center variables
The following table lists IBM® Control Center event elements that you can use as variables in operating system and server command actions, email actions, metadata actions, and workflow SLC correlators. A brief description of each element is also included.
The event elements are listed in alphabetical order. For each variable, the relevant server types are indicated by an x in one or more of the following columns:
- CD (Sterling Connect:Direct®)
- CE (Sterling Connect:Enterprise®)
- CX (Sterling Connect:Express)
- SI (Sterling B2B Integrator, including Sterling File Gateway)
- QF (QuickFile)
- MQ (MQ MFT)
- FTP (FTP servers of all types)
- GM (Global Mailbox)
- SCC (IBM Control Center)
| Event Element | CD | CE | CX | SI | QF | MQ | FTP | GM | SCC | Description |
| action | x | Action performed on IBM Control Center entity. | ||||||||
| actionId | x | Name of an action called by a rule. | ||||||||
| activityType | x | A code that indicates the type of SLC activity an SLC event is associated with.
| alert | x | x | x | x | x | x | x | x | x | Alert level/severity. |
| applAgentType | x | Application Agent type. | ||||||||
| batchId | x | Batch ID. | ||||||||
| batchNumber | x | Batch number. | ||||||||
| bytesRead | x | x | x | Number of bytes read from the source file. | ||||||
| bytesSent | x | x | x | Number of bytes sent to the destination file. | ||||||
| bytesTransferred | x | Number of bytes transferred from the source file to the destination file. | ||||||||
| bytesXferred | x | x | x | Number of bytes received by the destination file. | ||||||
| CBEA | x | Control Block Encryption Algorithm. | ||||||||
| CERI | x | Certificate Issuer. | ||||||||
| CERT | x | Certificate Subject. | ||||||||
| CKPT | x | Check Point. | ||||||||
| CLAS | x | Class. | ||||||||
| CNOD | x | CT Node. | ||||||||
| controlCenterName | x | IBM Control Center name. | ||||||||
| CPUS | x | CPU Time (milliseconds). | ||||||||
| CSPE | x | Sterling Connect:Direct Secure Plus. | ||||||||
| CSPP | x | Secure Protocol. | ||||||||
| CSPS | x | Secure Cipher Suite. | ||||||||
| CSTN | x | Current® Signature Verified. | ||||||||
| CX.CRCO | x | CRC used. | ||||||||
| CX.EVT | x | Event type. Possible values are:
| CX.FAPI | x | User description of the file transfer. | ||||||||
| CX.FBYT | x | File bytes transferred. | ||||||||
| CX.FLAB | x | File label (PeSIT pi37). | ||||||||
| CX.FLAO | x | Interconnected File Agent is active. | ||||||||
| CX.FNRD | x | Number of records transferred. | ||||||||
| CX.FRLG | x | Local record length. | ||||||||
| CX.FTOP | x | Type-structure-mode options. | ||||||||
| CX. FTSU | x | Store unique option. | ||||||||
| CX.LNAM | x | Local node name. | ||||||||
| CX.LPHN | x | Local file name. | ||||||||
| CX.MULT | x | Multi-article is used in fpfu data. | ||||||||
| CX.NBYT | x | Network bytes transferred. | ||||||||
| CX.NMGS | x | Network message size. | ||||||||
| CX.NRC | x | Network return code. | ||||||||
| CX.OS | x | Operating system. | ||||||||
| CX.PI11 | x | PeSIT File Type. | ||||||||
| CX.PI15 | x | File date and time creation. | ||||||||
| CX.PID | x | Process identifier of the process that executed the request. | ||||||||
| CX.PNAM | x | Other node name. | ||||||||
| CX.PRC | x | Protocol return code. | ||||||||
| CX.PRIO | x | Transfer priority. | ||||||||
| CX.PROT | x | File transfer protocol. Possible values are:
| CX.REQD | x | Request accepted date. | ||||||||
| CX.REQR | x | Name of the entity that submitted the request. | ||||||||
| CX.RETN | x | Number of retries. | ||||||||
| CX.RSTA | x | Transfer status. | ||||||||
| CX.SRC | x | System return code. | ||||||||
| CX.TBDA | x | Beginning of transfer date/time. | ||||||||
| CX.TCPA | x | Remote node TCP/IP address. | ||||||||
| CX.TCPH | x | Remote node host name. | ||||||||
| CX.TCPP | x | Remote node port number. | ||||||||
| CX.TDIR | x | Transfer direction. Possible values are:
| CX.TDST | x | Transfer destination. | ||||||||
| CX.TEDA | x | End of transfer date/time. | ||||||||
| CX.TIDT | x | Transfer identified. | ||||||||
| CX.TOM | x | Server name. | ||||||||
| CX.TORG | x | Transfer origin. | ||||||||
| CX.TRC | x | Return code. | ||||||||
| CX.TRCV | x | Receiver of the file. | ||||||||
| CX.TRTN | x | Translation table identifier | ||||||||
| CX.TSND | x | Sender of the file. | ||||||||
| CX.TYPC | x | Compression type. | ||||||||
| CX.TYPD | x | Data type. | ||||||||
| CX.TYPF | x | File type. | ||||||||
| CX.TYPL | x | Type of link. Possible values are:
| CX.TYPN | x | Notification type. | ||||||||
| CX.TYPP | x | Partner type. | ||||||||
| CX.TYPR | x | Request type. Possible values are:
| CX.TYPU | x | Process originator. Possible values are:
| CX.USDR | x | User data received (PeSIT Pi99), associated to file. | ||||||||
| CX.USDS | x | User data sent (PeSIT pi99), associated to file. | ||||||||
| daemonHost | x | DNS host name or IP address of the system the Sterling Connect:Enterprise daemon is on. | ||||||||
| daemonName | x | Name of the Sterling Connect:Enterprise daemon. | ||||||||
| daemonOriginator | x | Originator of the Sterling Connect:Enterprise daemon. | ||||||||
| daemonPid | x | Process identifier of the Sterling Connect:Enterprise daemon. | ||||||||
| daemonResource | x | Resource of the Sterling Connect:Enterprise daemon. | ||||||||
| daemonSid | x | Session identifier of the Sterling Connect:Enterprise daemon. | ||||||||
| daemonState | x | State of the Sterling Connect:Enterprise daemon. | ||||||||
| daemonType | x | Type of the Sterling Connect:Enterprise daemon. IBM Control Center monitors only daemons of type master. | ||||||||
| dateTime | x | x | x | x | x | x | x | x | x | The date and time that the event was generated. |
| daysBeforeExpiry | x | An integer value that tells the number of days before certificate expiration. | ||||||||
| DBUG | x | Debug. | ||||||||
| DBYW | x | Bytes Written. | ||||||||
| DBYX | x | Bytes Received. | ||||||||
| DDS1 | x | Destination Disposition 1. | ||||||||
| DDS2 | x | Destination Disposition 2. | ||||||||
| DDS3 | x | Destination Disposition 3. | ||||||||
| destFile | x | x | x | x | x | x | x | x | x | Destination file name. For Sterling Connect:Direct, the file name at the destination in a copy step of a Process. For QuickFile, QF.File when file is downloaded and QF.packageSubject when file is uploaded. |
| direction | x | x | x | x | x | x | Indicates direction of file transmissions.
| DRCW | x | Records written. | ||||||||
| DRUX | x | RUs received. | ||||||||
| ECMP | x | Extended compression. | ||||||||
| EPRT | x | Execution Priority. | ||||||||
| eventId | x | x | x | x | x | x | x | x | x | The ID number assigned by the system to each event. |
| eventType | x | x | x | x | x | x | x | x | x | A code indicating the type of event. See Event Type Descriptions for a listing of event types and descriptions. |
| eventTypeDescr | x | x | x | x | x | x | x | x | x | A description for the event type. |
| executingProcs | x | x | Number of Processes in execution state. | |||||||
| FDBK | x | Feedback. | ||||||||
| FG.CONS_ORG_KEY | x | Sterling File Gateway Consumer Org Key. | ||||||||
| FG.DATA_FLOW_ID | x | Sterling File Gateway Data Flow ID. | ||||||||
| FG.EVENT_CODE | x | Sterling File Gateway Event Code. | ||||||||
| FG.FILE_NAME | x | Sterling File Gateway Arrived File Name. | ||||||||
| FG.PROD_ORG_KEY | x | Sterling File Gateway Arrived File Producer Org Key. | ||||||||
| FG.STATE | x | Sterling File Gateway Arrived File State. | ||||||||
| fgActivityType | x | Sterling File Gateway activity type
| fileSize | x | x | x | x | x | x | x | x | The size of the file transferred. | |
| fromNode | x | x | x | x | x | x | x | The node that sent the file:
| FUNC | x | Function information. | ||||||||
| groupId | x | SLC name. | ||||||||
| HOLD | x | Hold. | ||||||||
| inError | x | Indicates an error occurred during business process execution. | ||||||||
| isBP | x | Event is associated with a Sterling B2B Integrator business process. | ||||||||
| jobId | x | Job ID. | ||||||||
| jobName | x | x | Job Name. | |||||||
| LCCD | x | Local Return Code. | ||||||||
| lineName | x | Line Name. | ||||||||
| listName | x | List Name. | ||||||||
| LKFL | x | Link Fail. | ||||||||
| LMSG | x | Local Message ID. | ||||||||
| LNOD | x | Local Node. | ||||||||
| localNode | x | x | x | Server that processed the file. | ||||||
| mailboxFlags | x | Mailbox Flags. | ||||||||
| mailBoxId | x | Mailbox ID. | ||||||||
| maxExecutingProcs | x | x | Maximum number of concurrently executing Processes. | |||||||
| MCSI | x | Merged signature. | ||||||||
| MEMA | x | Alias Member Name. | ||||||||
| MEMB | x | Target Member Name. | ||||||||
| mepLastOccurrence | x | x | The last occurrence of maximum number of concurrently executing Processes. | |||||||
| mepOccurrences | x | x | Number of times maximum number of concurrently executing Processes occurred. | |||||||
| messageId | x | x | x | x | x | x | x | x | x | Server or IBM Control Center message ID issued with the event. |
| milestoneId | x | Name of milestone. | ||||||||
| MPEA | x | Merge EA. | ||||||||
MQMFT.action |
x | The MQ MFT action type. | ||||||||
MQMFT.action.time |
x | The MQ MFT action time. | ||||||||
MQMFT.call.crslt.oc |
x | The call outcome. | ||||||||
MQMFT.call.crslt.rslt.error |
x | The call result error. | ||||||||
MQMFT.call.crslt.rslt.oc |
x | The call result outcome. | ||||||||
MQMFT.call.crslt.rslt.rc |
x | The call result return code. | ||||||||
MQMFT.call.crslt.rslt.stderr |
x | The call result stderr output. | ||||||||
MQMFT.call.crslt.rslt.stdout |
x | The call result stdout output. | ||||||||
MQMFT.call.crslt.rslt.time |
x | The call result time. | ||||||||
MQMFT.call.crslt.retries |
x | The call result retries. | ||||||||
MQMFT.call.cmd.argument |
x | The call command arguments. | ||||||||
MQMFT.call.cmd.name |
x | The call command name. | ||||||||
MQMFT.call.cmd.retryCount |
x | The call command retry count. | ||||||||
MQMFT.call.cmd.retryWait |
x | The call command retry wait. | ||||||||
MQMFT.call.cmd.successRC |
x | The call command successful return code. | ||||||||
MQMFT.call.cmd.type |
x | The call command type. | ||||||||
MQMFT.destAgent.QMgr |
x | The destination queue manager. | ||||||||
MQMFT.destAgent.agent |
x | The destination agent. | ||||||||
MQMFT.destAgent.bridgeURL |
x | The destination bridge URL. | ||||||||
MQMFT.destAgent.systemInfo.arch |
x | The destination operating system arch. | ||||||||
MQMFT.destAgent.systemInfo.name |
x | The destination operating system name. | ||||||||
MQMFT.destAgent.systemInfo.ver |
x | The destination operating system version. | ||||||||
MQMFT.ID |
x | The MQ MFT identifier for the transfer. | ||||||||
MQMFT.job.name |
x | The job name (if provided), otherwise, "MQMFT_transfer". | ||||||||
MQMFT.metaData.metaData |
x | User provided metadata. | ||||||||
MQMFT.originator.hostName |
x | Hostname of the originator. | ||||||||
MQMFT.originator.mqmdUserID |
x | The originator MQMD user ID. | ||||||||
MQMFT.originator.userID |
x | The originator user ID. | ||||||||
MQMFT.postdestCall.crslt.oc |
x | The postdest call outcome. | ||||||||
MQMFT.postdestCall.crslt.rslt.error |
x | The postdest call result error. | ||||||||
MQMFT.postdestCall.crslt.rslt.oc |
x | The postdest call result outcome. | ||||||||
MQMFT.postdestCall.crslt.rslt.rc |
x | The postdest call result return code. | ||||||||
MQMFT.postdestCall.crslt.rslt.stderr |
x | The postdest call result stderr. | ||||||||
MQMFT.postdestCall.crslt.rslt.stdout |
x | The postdest call result stdout. | ||||||||
MQMFT.postdestCall.crslt.rslt.time |
x | The postdest call result time. | ||||||||
MQMFT.postdestCall.crslt.retries |
x | The postdest call result retries. | ||||||||
MQMFT.postdestCall.cmd.argument |
x | The postdest command arguments. | ||||||||
MQMFT.postdestCall.cmd.name |
x | The postdest command name. | ||||||||
MQMFT.postdestCall.cmd.retryCount |
x | The postdest command retry count. | ||||||||
MQMFT.postdestCall.cmd.retryWait |
x | The postdest command retry wait. | ||||||||
MQMFT.postdestCall.cmd.successRC |
x | The postdest command successful return. | ||||||||
MQMFT.postdestCall.cmd.type |
x | The postdest command type. | ||||||||
MQMFT.postsrcCall.crslt.oc |
x | The postsrc call outcome. | ||||||||
MQMFT.postsrcCall.crslt.rslt.error |
x | The postsrc call error. | ||||||||
MQMFT.postsrcCall.crslt.rslt.oc |
x | The postsrc call result outcome. | ||||||||
MQMFT.postsrcCall.crslt.rslt.rc |
x | The postsrc call result return code. | ||||||||
MQMFT.postsrcCall.crslt.rslt.stderr |
x | The postsrc call result stderr output. | ||||||||
MQMFT.postsrcCall.crslt.rslt.stdout |
x | The postsrc call result stdout output. | ||||||||
MQMFT.postsrcCall.crslt.rslt.time |
x | The postsrc call result time. | ||||||||
MQMFT.postsrcCall.crslt.retries |
x | The postsrc call result retries. | ||||||||
MQMFT.postsrcCall.cmd.argument |
x | The postsrc command arguments. | ||||||||
MQMFT.postsrcCall.cmd.name |
x | The postsrc command name. | ||||||||
MQMFT.postsrcCall.cmd.retryCount |
x | The postsrc command retry count. | ||||||||
MQMFT.postsrcCall.cmd.retryWait |
x | The postsrc command retry wait. | ||||||||
MQMFT.postsrcCall.cmd.successRC |
x | The postsrc command successful return. | ||||||||
MQMFT.postsrcCall.cmd.type |
x | The postsrc command type. | ||||||||
MQMFT.predestCall.crslt.oc |
x | The predest call outcome. | ||||||||
MQMFT.predestCall.crslt.rslt.error |
x | The predest call result error. | ||||||||
MQMFT.predestCall.crslt.rslt.oc |
x | The predest call result outcome. | ||||||||
MQMFT.predestCall.crslt.rslt.rc |
x | The predest call result return code. | ||||||||
MQMFT.predestCall.crslt.rslt.stderr |
x | The predest call result stderr output. | ||||||||
MQMFT.predestCall.crslt.rslt.stdout |
x | The predest call result stdout output. | ||||||||
MQMFT.predestCall.crslt.rslt.time |
x | The predest call result time. | ||||||||
MQMFT.predestCall.crslt.retries |
x | The predest call result retries. | ||||||||
MQMFT.predestCall.cmd.name |
x | The predest call command name. | ||||||||
MQMFT.predestCall.cmd.retryCount |
x | The predest call result retry count. | ||||||||
MQMFT.predestCall.cmd.retryWait |
x | The predest call result retry wait. | ||||||||
MQMFT.predestCall.cmd.successRC |
x | The predest call result successful return. | ||||||||
MQMFT.predestCall.cmd.type |
x | The predest call command type. | ||||||||
MQMFT.presrcCall.crslt.oc |
x | The presrc call outcome. | ||||||||
MQMFT.presrcCall.crslt.rslt.error |
x | The presrc call result error. | ||||||||
MQMFT.presrcCall.crslt.rslt.oc |
x | The presrc call result. | ||||||||
MQMFT.presrcCall.crslt.rslt.rc |
x | The presrc call result return code. | ||||||||
MQMFT.presrcCall.crslt.rslt.stderr |
x | The presrc call result stderr output. | ||||||||
MQMFT.presrcCall.crslt.rslt.stdout |
x | The presrc call result stdout output. | ||||||||
MQMFT.presrcCall.crslt.rslt.time |
x | The presrc call result time. | ||||||||
MQMFT.presrcCall.crslt.retries |
x | The presrc call result retries. | ||||||||
MQMFT.presrcCall.cmd.argument |
x | The presrc command arguments. | ||||||||
MQMFT.presrcCall.cmd.name |
x | The presrc command name. | ||||||||
MQMFT.presrcCall.cmd.retryCount |
x | The presrc command retry count. | ||||||||
MQMFT.presrcCall.cmd.retryWait |
x | The presrc command retry wait. | ||||||||
MQMFT.presrcCall.cmd.successRC |
x | The presrc command successful return. | ||||||||
MQMFT.presrcCall.cmd.type |
x | The presrc command type. | ||||||||
MQMFT.srcAgent.QMgr |
x | The source agent queue manager. | ||||||||
MQMFT.srcAgent.agent |
x | The source agent name. | ||||||||
MQMFT.srcAgent.bridgeURL |
x | The source agent bridge URL. | ||||||||
MQMFT.srcAgent.systemInfo.arch |
x | The source agent operating system arch. | ||||||||
MQMFT.srcAgent.systemInfo.name |
x | The source agent operating system name. | ||||||||
MQMFT.srcAgent.systemInfo.ver |
x | The source agent version. | ||||||||
MQMFT.statistics.actualStartTime |
x | Statistics actual start time. | ||||||||
MQMFT.statistics.numFileFailures |
x | Statistics number of file failures. | ||||||||
MQMFT.statistics.numFileWarnings |
x | Statistics number of file warnings. | ||||||||
MQMFT.statistics.retryCount |
x | Statistics retry count. | ||||||||
MQMFT.status.rsltCode |
x | The result code. | ||||||||
MQMFT.status.supplement |
x | MQ MFT message. | ||||||||
MQMFT.ts.item.dest.cs |
x | The destination checksum. | ||||||||
MQMFT.ts.item.dest.cs.meth |
x | The destination checksum method. | ||||||||
MQMFT.ts.item.dest.exist |
x | The destination exists. | ||||||||
MQMFT.ts.item.dest.lmod |
x | The destination last modification. | ||||||||
MQMFT.ts.item.dest.queue.groupId |
x | The destination queue group ID. | ||||||||
MQMFT.ts.item.dest.queue.msgCount |
x | The destination queue message. | ||||||||
MQMFT.ts.item.dest.queue.msgId |
x | The destination queue message ID. | ||||||||
MQMFT.ts.item.dest.queue.msgLength |
MQMFT.ts.item.dest.size |
x | The destination file size. | ||||||||
MQMFT.ts.item.mode |
x | The transfer mode. | ||||||||
MQMFT.ts.item.src.cs |
x | The source checksum. | ||||||||
MQMFT.ts.item.src.cs.meth |
x | The source checksum method. | ||||||||
MQMFT.ts.item.src.disp |
x | The source disposition. | ||||||||
MQMFT.ts.item.src.lmod |
x | The source last modified date/time. | ||||||||
MQMFT.ts.item.src.queue.groupId |
x | The source queue group ID. | ||||||||
MQMFT.ts.item.src.queue.msgCount |
x | The source queue message count. | ||||||||
MQMFT.ts.item.src.queue.msgId |
x | The source queue message ID. | ||||||||
MQMFT.ts.item.src.queue.msgLength |
x | The source queue message length. | ||||||||
MQMFT.ts.item.src.size |
x | The source file size. | ||||||||
MQMFT.ts.item.status.rsltCode |
x | The transfer result code. | ||||||||
MQMFT.ts.item.status.supplement |
x | The transfer message. | ||||||||
MQMFT.ts.startTime |
x | The transfer start time. | ||||||||
| nodeId | x | x | x | x | x | x | x | The server alias. | ||
| nodeName | x | x | x | x | x | x | x | The actual name of the server. For QuickFile, comes from QF.serverName. | ||
| nodeType | x | x | x | x | x | x | x | x | x | The code indicating the type of server. The server types are:
| nodeTypeDescr | x | x | x | x | x | x | x | x | A description of the server type. | |
| nonExecutingProcs | x | x | Number of nonexecuting Processes. | |||||||
| objectId | x | ID of object associated with the event. | ||||||||
| objectType | x | Type of object associated with the event. | ||||||||
| objectVersion | x | Version of object associated with the event. | ||||||||
| OCCD | x | Other Return Code. | ||||||||
| oid | x | Object Identifier. | ||||||||
| OMSG | x | Other Message ID. | ||||||||
| origNode | x | x | x | x | x | x | The originating node of a process. QuickFile, comes from QF.serverName. | |||
| PACC | x | Pnode Accounting Information. | ||||||||
| PCSI | x | Pnode Signature. | ||||||||
| PEAL | x | Pnode Encryption Algorithm List. | ||||||||
| percentComplete | x | x | x | The percent complete of the file copy or transfer. | ||||||
| PPEA | x | Pnode Encryption Data. | ||||||||
| PPLX | x | Pnode Plex Class. | ||||||||
| processData | x | Sterling B2B Integrator process data. | ||||||||
| processId | x | x | x | x | x | x | x | The Process ID or batch number. QuickFile, comes from QF.packageId. | ||
| processIds | x | x | A list of Process IDs or batch numbers in a Process Queue event. | |||||||
| processName | x | x | x | x | x | x | x | The Process name or batch ID. | ||
| processNames | x | A list of Process names or batch IDs in a Process Queue event. | ||||||||
| processQueue | x | x | x | x | x | The queue containing the Process. | ||||
| processQueues | x | A list of queues in a Process Queue event. | ||||||||
| protocol | x | Protocol. | ||||||||
| PRTY | x | Priority. | ||||||||
| PSIN | x | Previous Signature Verified. | ||||||||
QF.eventType |
x | Type of QuickFile event. | ||||||||
QF.file |
x | Name of file. | ||||||||
QF.operation |
x | Event operation. | ||||||||
QF.recipient.userEmail |
x | Recipient user email address. | ||||||||
QF.recipient.userFullname |
x | Recipient user full name. | ||||||||
QF.recipient.userId |
x | Recipient user ID. | ||||||||
QF.userEmail |
x | User email address. | ||||||||
QF.userRegistered |
x | Boolean indicator as to whether QuickFile user is registered or not. Values are true | false. | ||||||||
| QUEU | x | Queue. | ||||||||
| RCCT | x | Record Category. | ||||||||
| recCat | x | x | Record Category. | |||||||
| recipientMailboxId | x | Recipient Mailbox ID. | ||||||||
| recordId | x | x | The type of statistics record from the event. | |||||||
| relativeSelectStmt | x | Relative Select Statement. | ||||||||
| remoteName | x | Remote Name. | ||||||||
| remoteNode | x | x | x | x | x | x | x | Name of the remote server involved in a process or file transfer. | ||
| remoteNodes | x | x | A list of remote servers in a Process Queue event. | |||||||
| RETN | x | Retain. | ||||||||
| returnCode | x | x | x | x | x | x | x | x | x | A numeric code returned from a completed process that indicates failure or success. For QuickFile, based on last letter of the messageId. If the last letter is l, the return code is 0; otherwise, it is 8. |
| RSTR | x | Restart. | ||||||||
| ruleId | x | x | x | x | x | x | x | x | x | The name of the rule triggered by the event. |
| ruleInstanceId | x | x | x | x | x | x | x | x | x | Rules Instance ID used when there is a linked rule. |
| ruleMemberName | x | Rule Member Name. | ||||||||
| ruleName | x | Sterling Connect:Enterprise for z/OS® Rule Name. | ||||||||
| RUSZ | x | RU Size. | ||||||||
| SACC | x | Snode Accounting Information. | ||||||||
| SBND | x | Submit Node. | ||||||||
| SCHD | x | Scheduled Date/Time. | ||||||||
| SCMP | x | Standard Compression. | ||||||||
| SCSI | x | Snode Signature. | ||||||||
| SDS1 | x | Source Disposition 1. | ||||||||
| SDS2 | x | Source Disposition 2. | ||||||||
| SDS3 | x | Source Disposition 3. | ||||||||
| SEAL | x | Snode Encryption Algorithm List. | ||||||||
| seqNum | x | x | x | x | x | x | x | x | x | Sequence. |
| session | x | Sterling B2B Integrator Session. | ||||||||
SESSION.ADAPTER_ |
x | Sterling B2B Integrator system adapter name. | ||||||||
SESSION.ADAPTER_ |
x | Sterling B2B Integrator adapter type. | ||||||||
SESSION.CHILD_ |
x | Sterling B2B Integrator Session child session ID. | ||||||||
SESSION.CON_END_ |
x | Sterling B2B Integrator Session connection end time. | ||||||||
SESSION.CON_IS_ |
x | Sterling B2B Integrator Session connection successful. | ||||||||
SESSION.CON_START_ |
x | Sterling B2B Integrator Session connection start time. | ||||||||
| SESSION.DIS_END_TIME | x | Sterling B2B Integrator Session disconnect end time. | ||||||||
SESSION.DIS_IS_ |
x | Sterling B2B Integrator Session disconnect is success. | ||||||||
SESSION.DIS_START_ |
x | Sterling B2B Integrator Session disconnect start time. | ||||||||
| SESSION.END_WFID | x | Sterling B2B Integrator Session end workflow ID. | ||||||||
| SESSION.END_WFSTEP | x | Sterling B2B Integrator Session end workflow step. | ||||||||
| SESSION.ENDPOINT1 | x | Sterling B2B Integrator Session end point 1. | ||||||||
| SESSION.ENDPOINT2 | x | Sterling B2B Integrator Session end point 2. | ||||||||
| SESSION.ENDPORT1 | x | Sterling B2B Integrator Session end port 1. | ||||||||
| SESSION.ENDPORT2 | x | Sterling B2B Integrator Session end port 2. | ||||||||
| SESSION.ERROR_MSG | x | Sterling B2B Integrator Session error message. | ||||||||
| SESSION.IS_LOCAL_INIT | x | Sterling B2B Integrator Session is locally initialized. | ||||||||
| SESSION.PRINCIPAL | x | Sterling B2B Integrator Protocol Activity Session principal. | ||||||||
| SESSION.PROTOCOL | x | Sterling B2B Integrator protocol of file movement. | ||||||||
| SESSION.PS_INSTANCE | x | Sterling B2B Integrator Protocol Activity Session PS instance. | ||||||||
| SESSION.SECURE_MODE | x | Sterling B2B Integrator Protocol Activity Session secure mode. | ||||||||
SESSION.SESSION_ |
x | Sterling B2B Integrator Protocol Activity Session archive ID. | ||||||||
| SESSION.SESSION_ID | x | Sterling B2B Integrator Protocol Activity Session ID. | ||||||||
| SESSION.START_WFID | x | Sterling B2B Integrator Protocol Activity Session start workflow ID. | ||||||||
| SESSION.START_WFSTEP | x | Sterling B2B Integrator Protocol Activity Session start workflow step. | ||||||||
| SESSION.STATUS_CODE | x | Sterling B2B Integrator Protocol Activity Session status code. | ||||||||
| shortText | x | x | x | x | x | x | x | x | x | Message text associated with the Message ID. |
| SI.MESSAGE_ID | x | Sterling B2B Integrator/Sterling File Gateway message ID. | ||||||||
| slcId | x | A system-assigned name of the SLC that triggered the event. | ||||||||
| slcInstanceId | x | Unique SLC identifier. Includes the SLC name, schedule name, and unique number. | ||||||||
| slcSource1 | x | SLC recovery data 1. | ||||||||
| slcSource2 | x | SLC recovery data 2. | ||||||||
| SMEM | x | Source Member Name. | ||||||||
| SOPT | x | SYSOPTS parameter in a Sterling Connect:Direct Process step. | ||||||||
| sourceEventTime | x | The time that the event triggering an SLC event occurred. | ||||||||
| sourceFile | x | x | x | x | x | x | x | The source file name in a Copy. Also the target in a Submit, Run Task, or Run Job Sterling Connect:Direct Process step. For QuickFile, QF.File when file is uploaded and QF.package when file is downloaded. | ||
| SPEA | x | Snode Encryption Data. | ||||||||
| SPLX | x | Snode Plex Class. | ||||||||
| SRCR | x | Records Read. | ||||||||
| SRUX | x | RUs Sent. | ||||||||
| SRVR | x | Server Name. | ||||||||
| STAT | x | Status. | ||||||||
| status | x | x | Status. | |||||||
| stepName | x | x | x | The name of the Sterling Connect:Direct Process step or Sterling B2B Integrator business Process activity. | ||||||
| STPT | x | Stop Date/Time. | ||||||||
| STRT | x | Start Date/Time. | ||||||||
| SUBI | x | Submitter Node. | ||||||||
| submitter | x | x | x | x | User ID of the Process submitter. | |||||
| submitterId | x | x | x | x | x | x | x | x | x | The user ID of the work submitter. For QuickFile, user fullname. |
| submitterIds | x | x | A list of Submitter IDs in a Process Queue event. | |||||||
| suspended | x | Indicates if a Process is suspended. | ||||||||
| TDSB | x | Submit Date/Time. | ||||||||
| timeUp | x | Time Up. | ||||||||
| triggerMilestoneId | x | Name of milestone that triggered the jeopardy SLC event. | ||||||||
| url | x | URL. | ||||||||
| userData1 | x | x | x | x | x | x | x | x | x | Metadata user data field 1. |
| userData2 | x | x | x | x | x | x | x | x | x | Metadata user data field 2. |
| userData3 | x | x | x | x | x | x | x | x | x | Metadata user data field 3. |
| userData4 | x | x | x | x | x | x | x | x | x | Metadata user data field 4. |
| userId | x | User associated with the event. | ||||||||
| WF.ACTIVITYINFO_ID | x | Business Process Activity Info ID. | ||||||||
| WF.ADV_STATUS | x | Business Process advanced status. | ||||||||
| WF.BASIC_STATUS | x | Business Process basic status. | ||||||||
| WF.END_TIME | x | Business Process end time. | ||||||||
| WF.NEXT_AI_ID | x | Business Process next AI ID. | ||||||||
| WF.NODEEXECUTED | x | Node where Business Process executed. | ||||||||
| WF.DOC_ID | x | Payload document ID of the Business Process. |
| WF.SERVICE_NAME | x | Service name in Business Process. | ||||||||
| WF.START_TIME | x | Business Process / Business Process Step start time. | ||||||||
| WF.STEP_ID | x | Business Process step ID. | ||||||||
| WF.WFD_ID | x | Business Process Definition ID. | ||||||||
| WF.WFD_NAME | x | Business Process name. | ||||||||
| WF.WFD_VERSION | x | Business Process Definition version. | ||||||||
| WF.WFE_STATUS | x | Business Process execution status. | ||||||||
| WF.WORKFLOW_ID | x | Business Process instance ID. | ||||||||
| wkFlow | x | Workflow. | ||||||||
| XFER.DOC_ID | x | Sterling B2B Integrator Protocol Activity Transfer document ID. | ||||||||
| XFER.DOC_NAME | x | Sterling B2B Integrator Protocol Activity document name. | ||||||||
| XFER.END_TIME | x | Sterling B2B Integrator Protocol Activity Transfer end time. | ||||||||
| XFER.FILE_SIZE | x | Sterling B2B Integrator Protocol Activity Transfer file size. | ||||||||
| XFER.IS_BIN_XFER | x | Sterling B2B Integrator Protocol Activity Transfer is binary. | ||||||||
| XFER.IS_PUT | x | Sterling B2B Integrator Protocol Activity Transfer is put. | ||||||||
| XFER.IS_SECURE | x | Sterling B2B Integrator Protocol Activity Transfer is secure. | ||||||||
| XFER.IS_SUCCESS | x | Sterling B2B Integrator Protocol Activity Transfer is success. | ||||||||
| XFER.KBYTES_XFER | x | Sterling B2B Integrator Protocol Activity KBytes transferred. | ||||||||
| XFER.MAILBOX_PATH | x | Sterling B2B Integrator Protocol Activity/Sterling File Gateway Arrived File Mailbox Path. | ||||||||
| XFER.MBOX_PATH | x | Sterling B2B Integrator Protocol Activity SI mailbox path. | ||||||||
| XFER.MESSAGE_ID | x | Sterling B2B Integrator Protocol Activity Transfer message ID. | ||||||||
| XFER.MESSAGE_NAME | x | Sterling B2B Integrator Protocol Activity message name. | ||||||||
XFER.REMOTE_ |
x | Sterling B2B Integrator Protocol Activity Transfer remote filename. | ||||||||
| XFER.START_TIME | x | Sterling B2B Integrator Protocol Activity Transfer start time. | ||||||||
| XFER.WFID | x | Sterling B2B Integrator Protocol Activity Transfer work ID. | ||||||||
| XFER.WFSTEP | x | Sterling B2B Integrator Protocol Activity Transfer workflow step. | ||||||||
| XFER.XFER_ERROR_MSG | x | Sterling B2B Integrator Protocol Activity Transfer error message. | ||||||||
| XFER.XFER_ID | x | Sterling B2B Integrator Protocol Activity Transfer ID. | ||||||||
XFER.XFER_STATUS_ |
x | Sterling B2B Integrator Protocol Activity Transfer status code. | ||||||||
| XLAT | x | Translate. |
