You can install the IBM® Control
Center engine
and console in a z/Linux environment.
Before you begin
- Before you install IBM Control
Center using
the Java™ installer, you must
install a 64-bit version of IBM System
z/Linux JRE. See Detailed System Requirements.
- Define localhost in etc/hosts.
- Set ulimit to unlimited for
the user that installs IBM Control
Center.
About this task
Use this procedure to install the engine and console in a z/Linux environment.
Note: If you
are upgrading from a prior version of
IBM Control
Center, see
Release Notes.
Procedure
- Transfer the CCInstall64.bin file to the computer where IBM Control
Center will be installed.
- Set the following environment variables:
- JAVA_HOME environment variable to the installed Java JRE.
- Set the PATH environment variable to include the absolute
path to the installed Java. For
example:
export JAVA_HOME=/opt/ibm/java_s390x_70/jre
export PATH=/opt/ibm/java_s390x_70/jre/bin:$PATH
- Start the installer using the following syntax:
sh CCInstall64.bin
- Specify appropriate values for all the prompts including the installation location. During
installation, IBM Control
Center updates various
scripts with the location of the JRE.
- After the installation is done, run configCC.sh to configure the
engine.
Attention: During the Event Processor Name installation step, you can use only
alphanumeric characters to name the event processor. The event processor name must be unique in the
database.
The location of the JRE must not be changed after IBM Control
Center is installed. If so, IBM Control
Center will no longer run. To upgrade
the JRE, first install the newer version of the JRE on the computer where IBM Control
Center has been installed. Then
reinstall IBM Control
Center at the same
location.
