You can use the Distinct values function to view all unique values
within a column.
About this task
To use the Distinct values function in column header complete the
procedure.
Procedure
In the Inventory application, click ITEMS.
- In the ITEMS grid, click the
icon on the column to see the
Distinct values option.
Select Distinct values from the listed option.
- In the Distinct values window, select the checkbox for one or more
values.
- Click Filter.
- To change the selected distinct values, click the Distinct values
filter label in the filter description field.
Note: When you select the distinct values window for a field with an existing filter, it
automatically selects all the currently filtered values. Changing the selection updates the filter,
and removing all selected values clears the filter.
