General information fields
Field definitions for general information fields.
Field name Description Usage information
Inventory Saving Expected Inventory Saving The difference in Current expected and the the solution recommended Inventory Values (a negative value implies an increase to inventory value).
Last Exported Date Last Exported Date Set automatically by the solution when the record is exported to the ERP.
Last Receipt Last Receipt Date The most recent Receipt Date where the Receipt Category is not equal to "EXC - Exclude".
Last Reviewed Last Reviewed Date Set automatically in the solution when an item is approved or deferred.
Next Review Next Review Date Set automatically by MIO Inventory Optimization when an item is Deferred.
OOB Service % Optimal/Optimal/Best Service Level % Expected Customer Service Level % based on "Optimal" Reorder Level Methods and "Best" Forecast Method.
OOB Status Type Optimal/Optimal/Best Status Type Status Type as of last PU when recalc run based on "Optimal" Reorder Level Methods and "Best" Forecast Method.
Service Level % Expected Customer Service Level % Value based on the solution Recommended Reorder Point and Reorder Quantity.
Status Type Status Type Assigned by the solution based on business rules to identify exceptions for work management.
