Getting started with Blueworks Live IQ
As an Editor, you can run AI-powered analysis on process blueprints to obtain performance insights, improvement recommendations, and hygiene evaluations.
Before you begin
Important: This feature is currently a technology preview.
To be able to use Blueworks Live IQ (technology preview), make sure that the following prerequisites are met:
Procedure
  1. To start using Blueworks Live IQ, open your process blueprint. Blueworks Live IQ uses the current version of the open blueprint as context, including its BPMN structure and all available metadata.
  2. Open the AI chat panel.
  3. Select the Blueworks Live IQ tile.
  4. Enter a question or choose one of the suggested prompts in the chat to start the conversation.
What to do next
See the following tutorials to explore the use-cases that Blueworks Live IQ is specifically trained for.
Note: Blueworks Live IQ retains your chat history across sessions for each process you interacted with. Your messages remain available unless you select Restart conversation Restart icon. When you restart, your entire chat history for that process is permanently cleared and cannot be recovered. Before you restart a conversation, make sure that you save or copy any information that you want to keep. If you generated a business case, you can also download the output as a PDF file.
