Disk drives or solid-state drives for the 8408-44E or 8408-E8E
Learn how to install, remove, and replace disk drives or solid-state drives (SSDs) in the IBM® Power® System E850 (8408-44E and 8408-E8E) systems.
If you are installing, removing, or replacing mainstream SSDs, it is not supported to mix mainstream drives with enterprise drives in disk arrays. Also, you will need to monitor the amount of life that is remaining in the mainstream drives. For more information about these drives, see Mainstream solid-state drives.
