Learn about the specifications and operating system requirements for the 4 Gb Single-Port Fibre Channel PCI-X 2.0 DDR Adapter.
The 4 Gigabit Single-Port Fibre Channel PCI-X 2.0 DDR Adapter is a 64 bit address/data, short form factor Peripheral Component Interconnect-X (PCI-X) adapter with an LC type external fiber connector that provides single initiator capability over an optical fiber link or loop. With the use of appropriate optical fiber cabling, this adapter provides the capability for a network of high-speed local and remote located storage. The 4 Gigabit Single-Port Fibre Channel PCI-X Adapter auto-negotiates for the highest data rate between adapter and an attaching device at 1 Gbps, 2 Gbps or 4 Gbps of which the device or switch is capable. Distances of up to 500 meters running at 1 Gbps data rate, up to 300 meters running at 2 Gbps data rate, and 4 Gbps data rate up to 150 meters are supported between the adapter and an attaching device or switch. When used with IBM® Fibre Channel storage switches supporting long-wave optics, distances of up to 10 kilometers are capable running at either 1 Gbps, 2 Gbps, or 4 Gbps data rates.
The 4 Gigabit Single-Port Fibre Channel PCI-X Adapter can be used to attach devices either directly, or with Fibre Channel switches. If attaching a device or switch with an SC type fiber connector, use of an LC-SC 50 micron fiber converter cable (#2456) or an LC-SC 62.5 micron fiber converter cable (#2459) is required.
| CCIN | Description | Feature code | FRU part number | Wrap plug part number |
| 280D | Tape controllers | 1905, 5758, and 5761 | 046K6838 or 003N5014 | 012R9314 |
| 280E | Disk controllers | 5760 | 046K6840 or 003N5016 | 012R9314 |
50/125 micron fiber (500 MHz*km bandwidth cable)
62.5/125 micron fiber (200 MHz*km bandwidth cable)
AIX 5L Version 5.3 with the 5300-04 Technology Level, or later
Red Hat Enterprise Linux version 4 U2, or later
SUSE Linux Enterprise Server 9 SP3, or later
IBM i V5R3M0 with PTFs, V5R3M5 with PTFs
IBM i V5R4M0, or later
