Learn about the specifications for the PCI-X DDR Dual-Channel
Ultra320 SCSI Adapter.
The PCI-X DDR Dual-Channel Ultra320 SCSI Adapter is a
high-performance SCSI adapter for Peripheral Component Interconnect-X
(PCI-X) and PCI systems. The adapter provides two SCSI channels (buses),
each capable of running 320 MBps (maximum). Each SCSI bus can either
be internal (on systems that support internal SCSI devices or backplane
attachments) or external, but not both. Internally attached Ultra320
devices run at a data rate of up to 320 MBps on systems that have
internal backplanes that support Ultra320 speeds.
The
adapter uses and supports low voltage differential (LVD) drivers and
receivers only.
PCI-X DDR dual-channel Ultra320 SCSI adapter specifications
- Item
- Description
- FRU number
- FC 0647, 5736, or 5775 is 42R4860* or 39J4996**
- FC 1912 is 42R4862* or 39J4998**
- * Designed to comply
with RoHS requirement.
** Not designed to
comply with the RoHS requirement.
- I/O bus architecture
- PCI 2.2 compliant
- Slot requirement
- One available 3.3 volt PCI or PCI-X slot
- Maximum number
- For system-specific
adapter placement information, see the PCI adapter placement for machine types 82xx and 91xx or the PCI adapter placement for machine type 94xx topic collections.
- Operating system or partition requirements
- AIX 5L™ Version 5.2 with
the 5200-08 Technology Level, or later
- AIX 5L Version 5.3 with
the 5300-03 Technology Level, or later
- AIX® Version 6.1 or later
- IBM® i V5R4 with V5R4M5 machine
code, or later
- Red Hat Enterprise Linux Version 4.5, or later
5.1, or later
- SUSE Linux Enterprise Server 10 Service Pack 1,
or later
- Required software or drivers
- AIX - devices.pci.1410c002
device driver package
- Linux - ipr driver Version 2.0.10.3 (or later)
for SLES 9 kernels, Version 2.0.11.1 (or later) for RHEL4 kernels, or Version
2.0.13 (or later) for kernel.org kernels (kernel version 2.6.12 or
later)
If
the IBM Prerequisite Web site
- Tools
- None
- Cables
- Attachment cables are included with the attaching subsystem or
device.
