Learn about the specifications for the 2-Port
Asynchronous EIA-232 PCI Adapter.
This adapter provides connection for two (2) asynchronous
EIA-232 devices. Ports are programmable to support asynchronous protocols
over an EIA-232 interface at line speeds up to 128 Kbps.
Figure 1. 2-Port
Features and specifications
- FRU number 80P4353 (Not designed to comply
with RoHS requirement.)
- 2 external DB09 connectors
- Exar Dual Async Controller, XR17D152
- EIA-232 compatible
- Supports Xon/Xoff offload
- Supports RTS/CTS or DTR/DSR off-load
- PCI Local Bus Specification Revision 2.2 compliant
- Bus width: 32 bit data and address
- Bus speed: 33 MHz
- Single slot, less than half-size PCI card
- Universal signaling (5V or 3.3V)
- FCC Class-B
- Power consumption: 1.3 watts (nominal), 2.465 watts (maximum)
- Hardware or software flow control
- Custom baud rates
- 16C850 UART equivalent
AIX 5L™ Version 5.2 with the 5200-04 Technology Level, and later
AIX
5L Version 5.3, and later
Red Hat Enterprise Linux version 4
SUSE Linux Enterprise Server 9 SP1
Note: If you are installing a new feature, ensure
that you have the software required to support the new feature and
that you determine if there are any existing prerequisites.
To do this, use the IBM® Prerequisite Web site at http://www-912.ibm.com/e_dir/eServerPrereq.nsf
