PCI Cryptographic Coprocessor (FC 4963)
Learn about the specifications for the PCI Cryptographic Coprocessor.
The PCI Cryptographic Coprocessor is designed to provide data security functions for PCI bus systems. The PCI cryptographic coprocessor provides high-performance secure hardware engines, including methods of transmitting data, verifying electronic signatures, bulk data encryption, and decryption.
The adapter is designed to FIPS PUB 140-1 Security Level 4 Standards.
Feature 4963
Each PCI Cryptographic Coprocessor is shipped from the factory with a certified device key. This electronic key, which is stored in the adapter's battery-powered and protected memory, digitally signs status messages to confirm that the PCI Cryptographic Coprocessor is genuine and that no tampering has occurred.
Attention:
  • If any of the secure module's tamper sensors are triggered by tampering or by accident, the PCI Cryptographic Coprocessor erases all data in the protected memory, including the certified device key. Incorrect removal of the batteries triggers the tamper sensors and destroys the certified device keys. The PCI Cryptographic Coprocessor cannot operate without the certified device keys. To protect the keys, follow the guidelines given in the documentation provided with the coprocessor.
  • The batteries keep the coprocessor powered on even when it is not installed in a system. When handling, installing, or removing the coprocessor, do not let the coprocessor circuits come in contact with any conductive surface or tools. Doing so can render the adapter permanently inoperable.
PCI cryptographic coprocessor specifications
Item
Description
FRU number
10J0357 (Not designed to comply with RoHS requirement.)
Battery kit
09J8199, Kit contains two batteries and a battery tray. Two kits are required for battery replacement.
Bus architecture
PCI version 2.1
Adapter slots
For system-specific adapter placement information, see the PCI adapter placement for machine types 82xx and 91xx or the PCI adapter placement for machine type 94xx topic collections.
Temperature range, stored
+33.8 degrees F (+1 degree C) to +140 degrees F (+60 degrees C)
Temperature range, operating
+50 degrees F (+10 degrees C) to +104 degrees F (+40 degrees C)
Connector
For manufacturing test use only. Not for use by customer.
If you are installing a new feature, ensure that you have the software required to support the new feature and that you determine if there are any existing prerequisites. To do this, use the IBM® Prerequisite Web site at http://www-912.ibm.com/e_dir/eServerPrereq.nsf Link outside information center.
Last updated: Fri, June 27, 2014
