Learn about the specifications for the 64-bit/66MHz PCI ATM 155
UTP Adapter.
The 64-bit/66MHz PCI ATM 155 UTP Adapter provides the interface
between the ATM 155 Mb/sec unshielded twisted pair network and the 64-bit/66
MHz PCI bus in your system.
64-bit/66MHz PCI ATM 155 UTP Adapter specifications
- Item
- Description
- FRU number
- 21P4112 (Not designed to comply
with RoHS requirement.)
- Bus architecture
- PCI 2.2
- Card type
- Half
- Adapter slots
- For system-specific
adapter placement information, see the PCI adapter placement for machine types 82xx and 91xx or the PCI adapter placement for machine type 94xx topic collections. .
- Wrap plug
- 21P8009 (Supplied with adapter) or 42H0540
- Connector information
- RJ-45
- Cables
- The cat5 cable can be unshielded twisted pair (UTP) or shielded twisted
pair (STP), up to 100 meters in length.
If
