Learn about the features of the PCIe 2-Line WAN with Modem.
This adapter is a 2-line/port WAN with Modem PCIe adapter. Port 0 is the modem port and supports V.92 56K Async PPP, V.92 data modem, V.44 data compression, V.34 FAX modem and FAX functions, such as ECM and 2D/1D conversion. Port 0 does not provide Sync modem capabilities (SDLC and Sync PPP). Port 1 is the RVX port and supports multiple communications protocols, including synchronous operations.
2893 or 9693 is the non-CIM (Complex Impedance Matching) version offered in all countries and regions except Australia and New Zealand.
2894 or 9694 is the CIM (Complex Impedance Matching) version offered only in Australia and New Zealand.
The FRU part numbers for the adapter are:
If
