Learn about specifications for the POWER® GXT135P
graphics PCI Adapter.
The POWER GXT135P graphics PCI Adapter is a high-performance
PCI graphics adapter that accelerates and enhances your system unit
video. This adapter has no hardware switches to set. Mode selection
is made through the software. Connection to the video monitor is made
through a high-density 15-pin D-shell connector or a 28-pin DVI connector.
Adapter specifications
- Item
- Description
- FRU number
- 03N5853* or 00P5758**
- * Designed to comply
with RoHS requirement.
** Not designed to
comply with the RoHS requirement.
- Bus architecture
- PCI
- Bus width
- 32-bit
- Memory
- 16 MB SDRAM
- Number of colors supported
- 8-bit or 24-bit
- Analog screen resolutions
- 640x480 at 60 Hz vertical refresh
- 1024x768 at 60 - 85 Hz vertical refresh
- 1280x1024 at 60 - 85 Hz vertical refresh
- 1600x1200 at 75 - 85 Hz vertical refresh
- 2048x1536 at 60 - 75 Hz vertical refresh
- Digital screen resolutions
- 1024x768 at 60 Hz vertical refresh
- 1280x1024 at 60 Hz vertical refresh
- 1600x1200 at 30 Hz vertical refresh
- Display power management
- Supports VESA and DPMS
- Connectors
- 15-pin D-shell connector
- 28-pin DVI-I connector
If
