Learn about the features of the PCI IOP for SAN Load Source.
This adapter provides the specialized function required to attach a IBM® i operating system load source by way of a Fibre Channel adapter and boot from that load source. Feature 2847 does not support multipath for the i load source disk unit, but does support multipath for all other logical units numbers (LUNs) attached to this IOP. A minimum of two IOPs are required for enabling redundancy.
If
the IBM Prerequisite Web site
