Learn about the features of the PCI IOP.
2844 is a PCI I/O processor that drives PCI IOA adapters in the system
unit and in HSL attached PCI or PCI-X I/O expansion units. A 2844 can drive
a maximum of four IOAs, subject to configuration restrictions.
- Fru number
- 39J1719 *
- 39J3242**
- * Designed to comply with RoHS requirement.
- ** Not designed to comply with the RoHS requirement.
If
