Learn about the features of this PCI Quad Modem IOA.
The PCI Quad Modem IOA is a four-line WAN modem adapter, with four RJ-11 ports, supports V.92 56K Async SLIP/PPP and V.34 Fax applications at data rates up to 33.6K via internal modems. Connection to the V.92 ports is via telephone cable. Remote power on via ring-indicator and SDLC are not supported.
2805 is non-CIM (Complex Impedance Matching).
0616 is a direct attach 2805 for use with Linux.
6808 is an IOPless 2805. 6808 does not support SNA communications except through the IBM® i operating system V5R4 Enterprise Extender function.
2806 has CIM (complex impedance matching).
0617 is a direct attach 2806 for use with Linux.
6809 is an IOPless 2806. 6809 does not support SNA communications except through the IBM i operating system V5R4 Enterprise Extender function.
If
the IBM Prerequisite Web site
