Learn about the features of the PCI 2-Line WAN IOA.
2742 is a 2-Line WAN IOA that supports up to two multiple protocol communications (RVX) ports.
Features 6805 and 0613 are physically the same adapter as 2742, but have different feature numbers that denote to IBM® configuration tools whether an IOP is required. Feature 0613 is a direct attach 2742 for use with Linux. Feature 6805 is a 2742 for use without an IOP.
If
the IBM Prerequisite Web site
