Learn about the specifications for the 4-Port USB PCI Express
(PCIe) Adapter.
The 4-Port USB PCIe Adapter is a single-lane (1x) PCIe
high-performance expansion adapter that provides the following features
and support:
- Compliance with PCIe base specification revision 1.1
- Single-lane (1x) PCI Express for a throughput of 2.5 Gbps
- Single-slot, half-length PCIe card
- FCC Class A
- Four downstream, external, high-speed USB 2.0 ports 1
- Data-transfer rates of 480 Mbps (high-speed), 12 Mbps (full-speed),
and 1.5 Mbps (low-speed)
- Full compliance with Universal Serial Bus (USB) specifications,
revision 1.1 and 2.0
- Simultaneous operation of multiple USB 2.0 and USB 1.1 devices
- Compliance with Enhanced Host Controller Interface (EHCI) and
Open Host Controller Interface (OHCI) standards
- Integrated dual-speed USB transceivers
- A total of 126 USB hubs and devices are supported by the adapter 1
1 The four external ports are shared and controlled
by three internal USB controllers. AIX might list only the three controllers;
however, all four ports are operational.
Figure 1. 4-Port USB PCIe Adapter
If
