Mirroring for client logical partitions
Achieve mirroring for client logical partitions by using two virtual SCSI adapters.
The client partition can mirror its logical volumes using two virtual SCSI client adapters. Each of these adapters should be assigned to separate Virtual I/O Server partitions. The two physical disks are each attached to a separate Virtual I/O Server partition and made available to the client partition through a Virtual SCSI server adapter. This configuration protects virtual disks in a client partition against the failure of any of the following:
The performance of your system might be impacted when using a RAID 1 configuration.
