Learn about all the tasks you need to perform to set up connectivity to service and support when you are working in a clustered environment.
This procedure contains the complete list of tasks needed to set up connectivity to service and support. Some of these tasks might already have been completed (during initial server setup, for example). If so, you can use this procedure to verify that the tasks were completed correctly.
In this document, an Internet connection is defined as access to the Internet from a logical partition, server, or HMC by direct or indirect access. Indirect means that you are behind a Network Address Translation (NAT) firewall. Direct means that you have a globally routable address without an intervening firewall, which would block the ports that are needed for communication to service and support.
Choose the method that best describes your situation.
The underlying framework of your service environment is networking. The following networking connections are required for you to be able to take advantage of electronic services such as reporting hardware problems and other server information and downloading updates:
You will need an IBM ID to register IBM Electronic Service Agent™ on the HMC and for Electronic Service Agent on your operating system or systems. You also will need this ID to view information that has been reported to IBM through Electronic Service Agent.
For details, refer to Installing operating systems.
For instructions, refer to the operating system documentation.
TCP/IP starts automatically, as long as the network adapter is recognized and can communicate with the network when the AIX or Linux operating system is started.
If you have an HMC, you do not need to obtain and configure Electronic Service Agent for AIX or Linux. The AIX and Linux inventory and hardware-problem information (or report, perhaps) are sent through the HMC. However, you might want to set up Electronic Service Agent on AIX or Linux to contact the software service organization.
You will need to install Electronic Service Agent on AIX or Linux to access the SA Basic User Interface. For details, refer to the Electronic Service Agent Web site and search for the appropriate Electronic Service Agent user's guide.
You might use this type of service connection if your server is not available, because the service processor does not require an operating system to perform its tasks.
To set up your service processor to connect to service and support, you need to attach a modem to the system port on your server. In addition, you need to use the Advanced System Management Interface (ASMI) menus to perform several configuration steps.
You can use the Internet to view details of the system you have enabled, and see the data collected by Electronic Service Agent. To use the advanced features and receive the full benefits of Electronic Service Agent, you must enter an IBM Registration ID (IBM ID). The first IBM ID entered will have Administrator authority and is able to authorize additional users on the Web site. The second IBM ID is available as a backup for the Administrator.
