Defining Properties to Export Data
You can specify properties to generate a Fastexport script
on the Output page of the TDMLoad Stage dialog
box.
About the Stage Page
You provide information on the General tab
on the Stage page to identify the target of the
import.
About the Output Page
The Output page has an Output
name field, a Columns... button,
and General, FastExport, Selection, SQL, and Columns tabs.
Compiling and Running the Job
Complete the definition of the other stages in your job
design according to normal IBM InfoSphere DataStage procedures.
Compile and run the job.
