Preserving Transport Utility Settings on Sandbox Before Database Refresh
To preserve the transport utility settings in the sandbox environment before you refresh the production database, the database dump that is taken from the production database should exclude the transport utility tables.
Procedure
To preserve the transport utility settings on sandbox before database refresh, complete the following steps:
  1. Use the following command to export the database dump of the source (production) environment by excluding the following three tables: OAUTH20CACHE, OAUTH20CLIENTCONFIG, OAUTH_USER_TOKEN. expdp vsm_src/pgm1@dq11r2e1 parfile=abc.txt
    abc.txt contains
    dumpfile=vsm_src_TU.dmp
    directory=dumps
    schemas=vsm_src
    logfile=vsm_src_TU.log
    EXCLUDE=TABLE:"IN ('OAUTH20CACHE', 'OAUTH20CLIENTCONFIG' , 'OAUTH_USER_TOKEN')"
  2. Export the dump of the target (sandbox) database users for the OAUTH20CACHE, OAUTH20CLIENTCONFIG, OAUTH_USER_TOKEN tables by using the following command.
    expdp <user name>/<password>@<IP address>:<port number>/<SID or Service name> directory=dumps dumpfile=vsm_trg_tables.dmp TABLES=vsm_trg.OAUTH20CACHE,vsm_trg.OAUTH20CLIENTCONFIG,vsm_trg.OAUTH_USER_TOKEN logfile=vsm_tables.log
  3. Drop the target database user and create a new database user by using standard script.
  4. Import the dump that was created in step 1 from the source setup to the target setup by using the following command.
    impdp <user name>/<password>@<IP address>:<port number>/<SID or Service name> dumpfile=vsm_src_TU.dmp logfile=vsm_src_TU.dmp.log DIRECTORY=DUMPS schemas=vsm_src REMAP_SCHEMA=vsm_src:vsm_trg REMAP_TABLESPACE=temp:temp
  5. Import the dump again on the target setup to retain the target Oath * by using the following command.
    impdp <user name>/<password>@<IP address>:<port number>/<SID or Service name> dumpfile=vsm_trg_tables.dmp logfile=vsm_tables.log DIRECTORY=DUMPS schemas=vs m_trg REMAP_SCHEMA=vsm_trg:vsm_trg REMAP_TABLESPACE=temp:temp
