Setting up for the FIN sample
This
section lists the prerequisites that must be met before you can successfully
invoke the FIN sample application.
- On Linux: Compile and link the FIN sample code.
- To simplify the setup, use the same queue manager as the Send and Receive message flows of the FIN services for the sample application.
- Optionally, define a service input queue for use as the reply
queue of the sample application. In the send mode, the reply queue
is specified by the -q parameter of the sample application (see page -q queue (string, max. 48 characters)).
DEFINE QLOCAL('Client.Receive') + PUT(ENABLED) + GET(ENABLED) + NOTRIGGER + DESCR('Local queue for FIN sample + application reply messages') + DEFPRTY(0) + DEFPSIST(NO) + MAXMSGL(4194304) + MAXDEPTH(5000) + BOQNAME(' ') + HARDENBO + MSGDLVSQ(FIFO) - Make sure that sufficient user access rights are given to the user ID starting the sample application to access the Send service interface queue.
- Make sure that you have configured the FIN services. For more information, see Configuring SIPN FIN services.
