Define custom egress network policy for Data Product Hub
You can define custom egress network policies for DataProduct API pods to enable controlled outbound traffic to external IP addresses and ports by setting up the externalEgress configuration.
The configuration is useful for:
- Allowing access to external databases
- Enabling connections to external APIs
- Configuring access to cloud services
- Implementing network security policies
- Access to OpenShift cluster with appropriate permissions
- DataProduct operator that is installed and running
- Existing DataProduct CR or the ability to create one
- Understanding of CIDR notation and network policies
Follow these steps to configure the externalEgress field in the DataProduct Custom Resource (CR) for external network egress management in an OpenShift cluster.
Step 1: Plan Your External Egress Rules
Identify your external egress rules before you configure externalEgress in DataProduct Custom Resource:
- External Services: What external services need to be accessed?
- IP Ranges: What are the CIDR blocks for these services?
- Protocols: TCP or UDP?
- Ports: Which ports are required?
Planning Table Example
| Service | CIDR Block | Protocol | Port | Purpose |
| External DB | 10.0.0.0/24 | TCP | 5432 | PostgreSQL database |
| External API | 192.168.1.0/24 | TCP | 443, 8443 | REST API endpoints |
| Cloud Service | 172.16.0.0/16 | TCP | 443 | Cloud provider services |
Step 2: Configure externalEgress in DataProduct Custom Resource
The following code block shows a basic configuration example to configure externalEgress in DataProduct Custom Resource:
apiVersion: data-product.cpd.ibm.com/v1beta1
kind: DataProduct
metadata:
namespace: cpd-instance
labels:
app.kubernetes.io/instance: ibm-cpd-data-product-controller-manager
app.kubernetes.io/managed-by: ibm-cpd-data-product-controller-manager
app.kubernetes.io/name: ibm-cpd-data-product-controller-manager
spec:
version: "5.3.0"
scaleConfig: "small"
storageClass: "managed-nfs-storage"
license:
accept: true
license: Enterprise
# External Egress Configuration
externalEgress:
cidrConfig:
# Rule 1: External database access
- ipBlock:
cidr: 10.0.0.0/24
ports:
- protocol: TCP
port: 5432
- protocol: TCP
port: 3306
# Rule 2: External API endpoints
- ipBlock:
cidr: 192.168.1.0/24
ports:
- protocol: TCP
port: 443
- protocol: TCP
port: 8443
# Rule 3: Cloud services
- ipBlock:
cidr: 172.16.0.0/16
ports:
- protocol: TCP
port: 443
Step 3: Apply the Configuration
Add or modify the externalEgress section in the spec.
oc edit dataproduct dataproduct-cr -n <namespace>
Step 4: Verify the Configuration
- Check the DataProduct CR:
oc get dataproduct dataproduct-cr -n <namespace> -o yaml
- Look for the
externalEgresssection in the spec:
spec:
externalEgress:
cidrConfig:
- ipBlock:
cidr: 10.0.0.0/24
ports:
- protocol: TCP
port: 443
- Extract externalEgress configuration only:
oc get dataproduct dataproduct-cr -n <namespace> -o jsonpath='{.spec.externalEgress}' | jq
Step 5: Verify NetworkPolicy Update
- The DataProduct operator automatically creates or updates the NetworkPolicy based on the
externalEgressconfiguration.
- List NetworkPolicies
oc get networkpolicy -n <namespace> | grep dataproduct
- Describe the NetworkPolicy
oc describe networkpolicy dataproduct-api-network-policy -n <namespace>
- The expected output shows egress rules to match your configuration:
Spec:
PodSelector: app=dataproduct-api
Allowing egress traffic:
To:
IPBlock:
CIDR: 10.0.0.0/24
Ports:
Protocol: TCP
Port: 5432
Protocol: TCP
Port: 3306
To:
IPBlock:
CIDR: 192.168.1.0/24
Ports:
Protocol: TCP
Port: 443
Protocol: TCP
Port: 8443
- View your NetworkPolicy YAML
oc get networkpolicy dataproduct-api-network-policy -n <namespace> -o yaml
Step 6: Test Connectivity
Test the connectivity from the DataProduct API Pod:
- Get the pod name:
oc get pods -n <namespace> | grep dataproduct-api
- Test connectivity to external service:
# Test TCP connection
oc exec -it <dataproduct-api-pod-name> -n <namespace> -- curl -v telnet://10.0.0.5:5432
# Test HTTPS endpoint
oc exec -it <dataproduct-api-pod-name> -n <namespace> -- curl -v https://192.168.1.10:443
# Test with timeout
oc exec -it <dataproduct-api-pod-name> -n <namespace> -- timeout 5 bash -c 'cat < /dev/null > /dev/tcp/10.0.0.5/5432'
Step 7: Monitor and troubleshoot
- Check the operator logs:
# Find operator pod
oc get pods -n <operator-namespace> | grep data-product-operator
# View logs
oc logs -f <operator-pod-name> -n <operator-namespace>
- Check the DataProduct Custom Resource status:
oc get dataproduct dataproduct-cr -n <namespace> -w
The outputs of your status fields look like this:
Status:CompletedReconciled: Your versionPercent: 100%
Configuration Examples
Example 1: Single External Database
externalEgress:
cidrConfig:
- ipBlock:
cidr: 10.20.30.0/24
ports:
- protocol: TCP
port: 5432
Example 2: Specific External API Endpoints
externalEgress:
cidrConfig:
- ipBlock:
cidr: 203.0.113.0/24 # External API server range
ports:
- protocol: TCP
port: 443
- protocol: TCP
port: 8443
- protocol: TCP
port: 9443
