Modify a hardware profile
You can change the settings for an IPMI hardware profile.
Before you begin
You can modify the following attributes only:
  • serialport, serialspeed, and serialflow attributes in the nodehm table
  • bmcport, username, and password attributes in the ipmi table
Important: Do not modify any other attributes in the xCAT database. Only these six attributes can be changed after a hardware profile is created. The remainder of the attributes cannot be modified as they can cause system errors and are not attributes related to a hardware profile.
About this task
To update an IPMI-based hardware profile, you can update the nodehm and the ipmi table. Update the attributes as mentioned in the following steps only:
Procedure
  1. Edit the hardware profile table nodehm. Run the tabedit nodehm command to open the Edit window.
    1. Find the node attribute __HardwareProfile_myhwprofile, where myhwprofile is the name of your hardware profile.
    2. Set a new value for the following attributes: serialport, serialspeed, and serialflow.
    3. Save and exit the Edit mode.
  2. Edit the hardware profile table ipmi. Run the tabedit ipmi command to open the Edit window.
    2. Set a new value for the following attributes: bmcport, username, and password.
  3. For the hardware profile to be available from the Web Portal, you must run the following command to load the hardware profile:
    plcclient.sh -d pcmhardwareprofileloader
Results
The IPMI hardware profile is updated.
