Exporting subelement history table with link to element in the past
You need to manually locate the element within the output. You can also use the -histoDate 1 option to insert into or update a history table.
The subelement history table (seH) is linked to element (elt) and not to the element history table (eltH.)
resmgr -export seH -colNames "dbIndex  invariant hostIdx name label
instance state origin date_DATE  action dte_DATE" -file
$DIR/seH_elt.dat
# type = seH
# col = dbIndex  invariant hostIdx name label instance state origin
# filter =
# order =
# sep = |_|
# sepRec =
# cmdLine = -export seH -colNames "dbIndex  invariant hostIdx name
label instance state origin date_DATE  action dte_DATE"
100000222|_||_|100000165|_|192.168.127.1_If<6>|_|192.168.127.1_IF:
6 ("16/1") (1000Mbps)|_|If<6>|_|on|_|inventory|_|04/10/2002
01:16|_|I|_|04/10/2002 01:16|_|
100000222|_||_|100000165|_|192.168.127.1_If<6>|_|"192.168.127.1_IF:
6 (""16/1"") (1000Mbps)"|_|If<6>|_|on|_|resmgr|_|04/15/2002
20:10|_|U|_|04/15/2002 20:10|_|
100000222|_||_|100000165|_|Delete_100000222_192.168.127.1_If<6>|_|"192.168.127.1_IF:
6 (""16/1"")
(1000Mbps)"|_|Delete_100000222_If<6>|_|off|_|inventory|_|11/20/2002
00:58|_|U|_|11/20/2002 00:58|_|
100000223|_||_|100000167|_|192.168.127.2_If<23>|_|192.168.127.2_IF:
23 ("Fa0/22") (0Mbps)|_|If<23>|_|on|_|inventory|_|04/10/2002
100000223|_||_|100000167|_|192.168.127.2_If<23>|_|"192.168.127.2_IF:
23 (""Fa0/22"") (0Mbps)"|_|If<23>|_|on|_|resmgr|_|04/15/2002
23 (100Mbps)|_|If<23>|_|on|_|inventory|_|12/04/2002
23:38|_|U|_|12/04/2002 23:38|_|
23 (100Mbps)|_|If<23>|_|on|_|resmgr|_|05/28/2003
18:47|_|U|_|05/28/2003 18:47|_|
100000224|_||_|100000196|_|dev3.quallaby.com_If<1>|_|dev3_IF:
1 (10Mbps)|_|If<1>|_|on|_|inventory|_|04/10/2002
1 (10Mbps)|_|If<1>|_|on|_|resmgr|_|04/15/2002
20:10|_|U|_|04/15/2002 20:11|_|
100000225|_||_|100000165|_|192.168.127.1_If<82>|_|192.168.127.1_IF:
82 ("4/28") (100Mbps)|_|If<82>|_|on|_|inventory|_|04/10/2002
100000225|_||_|100000165|_|192.168.127.1_If<82>|_|"192.168.127.1_IF:
82 (""4/28"") (100Mbps)"|_|If<82>|_|on|_|resmgr|_|04/15/2002
100000225|_||_|100000165|_|Delete_100000225_192.168.127.1_If<82>|_|"192.168.127.1_IF:
82 (""4/28"")
(100Mbps)"|_|Delete_100000225_If<82>|_|off|_|inventory|_|11/20/2002
100000226|_||_|100000168|_|192.168.127.3_If<9>|_|192.168.127.3_IF:
9 ("Fa0/8") (0Mbps)|_|If<9>|_|on|_|inventory|_|04/10/2002
100000226|_||_|100000168|_|192.168.127.3_If<9>|_|"192.168.127.3_IF:
9 (""Fa0/8"") (0Mbps)"|_|If<9>|_|on|_|resmgr|_|04/15/2002
9 (0Mbps)|_|If<9>|_|on|_|inventory|_|12/04/2002
100000227|_||_|100000179|_|192.168.3.62_If<30>|_|192.168.3.62_IF:
30 ("Fa29") (100Mbps)|_|If<30>|_|on|_|inventory|_|04/10/2002
