Additional options
You can use the following additional options with the export option.
Option Description
-filter Filter the results of the export command
-filterRule
Broaden your filtering capabilities by entering a string against which results are compared to find matches.
The syntax of the filter string is similar to the syntax of an SQL WHERE clause, so that you can filter on common SQL keywords such as OR, AND, LIKE, IN, and so forth.
-order List columns in order
-distinct Eliminate duplicate lines
-ListForced Force columns to display values
Using -filter
The following option lets filter the results of the export command.
-filter
List of filtered values "colname(value) ..", same syntax as -colNames. Lets you filter the results of a command.
The following table lists available -filter values:
Values Examples
is null, not null
name(is null)
name(not null)
Any character with * (like operator is used) name(*ddd*)
Any character (= operator is used) name(ddddd)
Relational operator (in,between,!=,>,<,..) 'any character'
AND is made between filters
name(!='ddd')
number(<='10')
name(in'ddd','aaa','bbb')
between('0 and 3')
resmgr -export elt -colNames "name profil state missing" -filter
"missing(between'0 and 3') name_UPPER(*BOST*)"
bulk100-boston_1000,18|_|bulk_100|_|on|_|0|_|
bulk100-boston_100,11|_|bulk_100|_|on|_|0|_|
bulk100-boston_1000,19|_|bulk_100|_|on|_|0|_|
