jvm-ping-response
The expected response to a jvm-ping command. Used to check that the crawler jvm is still alive and responsive.
Usage
internal
Attributes
| Name | Type | Description |
parse-receiver-port
String | The port the crawler uses to connect to the crawler's JVM for sending Java parser parse-requests. |
