boost
Elements contained in this node will be "boosted" to the top of the list of results
Attributes
  • boost-levels (Text default: -1) - Space separated list of clustering levels in which the document will be boosted (0 for the top level, 1 for the top level clusters, etc). -1 can be used to specify all levels.
  • boost-display (Any of: boost-and-list, boost-only default: boost-and-list) - Specifies what to do when a document may be boosted and present in the current result list at the same time.
    • boost-and-list: Duplicate the document and put it both under a schema.x.element.boost element and the schema.x.element.list.
    • boost-only: Just move the document under a schema.x.element.boost element and remove it from the schema.x.element.list (eventually adding to it a new lower-ranked document to ensure the right count).
  • name (NMToken)
  • type (NMToken)
  • precedence (Decimal number)
Children
  • Use these in the listed order. The sequence may not repeat.
    • document: (Zero or more) - One document to be clustered (input) or that has been clustered (in tree in the output) or a duplicate (in documents in the output)
