vse-index
Children
  • Use these in the listed order. The sequence may not repeat.
    • vse-index-option: (Zero or more) - Optional settings for the indexer-service.
    • vse-tags: (At most 1) - A container to hold url tag weights. Tag weights are applied at indexing time to modify the relevance of text based on HTML tags in the contents.
    • vse-url-equivs: (At most 1) - A container to hold url mappings.
    • vse-index-streams: (At most 1) - Specifying a set of indexing streams will override all of the options: stem, kb, segmenter, tokenizer, tokenizer-word tokenizer-punct (and the *2 versions).
    • binning-sets: (At most 1) - A specification for creating a refinement/binning from the input documents
