state-param
CGI parameter passed to the Vivisimo object WHILE browsing a state
Description
By convention, these parameters can be used to change the way the output is displayed while browsing a set of results. Regular schema.x.element.param tags can't be used because they are set once and for all when the object is first serialized and saved to a file for a further browsing. In query-meta the current CGI parameters are always passed to the object as state-params.
Attributes
  • async (Boolean default: true) - Asynchronous processing. For parse tags, should the request be enqueued (false) or processed before its next sibling. For other elements, this attribute only makes a difference when they contain asynchronous requests which need to be processed before the element is processed. In this case, when false the element's next sibling will only be processed after the current element, when true Watson™ Explorer won't wait for the current element to be processed before processing its next sibling.
  • elt-id (Integer) - Usage: Internal
  • max-elt-id (Integer) - Usage: Internal
  • execute-acl (Text)
  • process (Text) - An XPath determining which of the attributes and/or children will be processed. Currently only "", "*", "@*" and "*|@*" are supported.
  • name (Text) - Name of the parameter. More than one parameter with the same name can be passed to the Vivisimo object.
  • value (Text) - Value of the parameter.
Examples
Input Example:
  <field name="query" record="record"/>
  <param name="q" value="test"/>
  <form name="vivisimo">
  <input name="q" field="query"/>
  </form>
  <query form="vivisimo"/>
Output Example:
  <meta query=" test "/>
  </form>
  <query>
  <operator logic="and">
  <term field="query" str="test" position="0"/>
  </operator>
  </query>
Input Example:
  <field name="title" record="record"/>
  <field name="date"/>
  <operator name="OR" middle-string="OR" logic="or"/>
  <operator name="parenthesis" start-string="(" end-string=")" logic="bracket"/>
  <operator name="AND" middle-string="AND" logic="and" precedence="1"/>
  <operator name="squot" start-string="'" end-string="'" logic="phrase"/>
  <operator name="not" start-string="-" logic="not"/>
  <operator name="title" start-string="title:" field="title"/>
  <operator name="author" end-string="[au]" field="author"/>
  <operator name="date" start-string="[date[" end-string="]]" field="date"/>
  <operator name="near" start-string="{" middle-string="," end-string="}" logic="near"/>
  <param name="query" value="'r s' 't u OR v"/>
  <param name="query" value="-w"/>
  <param name="query" value="x-y"/>
  <param name="query" value="-title:'z a'"/>
  <param name="query" value="b[au] c [au]"/>
  <param name="query" value="[date[d]]"/>
  <param name="query" value="{e,f} {g , h}"/>
  <param name="query" value="-[au] -AND -OR -- "/>
  <param name="query" value="-- "/>
  <form name="f">
  <input name="query" field="query" syntax="OR AND parenthesis wildcard squot not title author date near"/>
  </form>
  <query form="f"/>
Output Example:
  <meta query=" r s 't u  | v w x-y z a b c e f g h [au] AND OR - - "/>
  <form name="f">
  </form>
  <query>
  <term field="query" str="r s" phrase="phrase" position="0"/>
  <term field="query" str="'t" position="1"/>
  <operator name="OR" middle-string="OR" logic="or">
  <term field="query" str="u" position="2"/>
  <term field="query" str="v" position="3"/>
  </operator>
  <operator name="not" start-string="-" logic="not">
  <term field="query" str="w" position="4"/>
  </operator>
  <term field="query" str="x-y" position="5"/>
  <term field="title" str="z a" phrase="phrase" position="6"/>
  </operator>
  <term field="author" str="b" position="7" processing="strict"/>
  <term field="author" str="c" position="8" processing="strict"/>
  <term field="date" str="d" position="9"/>
  <operator name="near" start-string="{" middle-string="," end-string="}" logic="near">
  <term field="query" str="e" position="10"/>
  <term field="query" str="f" position="11"/>
  </operator>
  <term field="query" str="g" position="12"/>
  <term field="query" str="h" position="13"/>
  </operator>
  <term field="query" str="[au]" position="14"/>
  </operator>
  <term field="query" str="AND" position="15"/>
  </operator>
  <term field="query" str="OR" position="16"/>
  </operator>
  <term field="query" str="-" position="17"/>
  </operator>
  <term field="query" str="-" position="18"/>
  </operator>
  </operator>
  </query>
