Replacing the USB cable and connector in the 8335-GTG or 8335-GTH system
To replace a USB cable and connector,
complete the steps in this procedure.
Procedure
Ensure that you have the electrostatic discharge (ESD) wrist strap on
and that the ESD clip is plugged into a ground jack or connected to an unpainted metal surface. If
not, do so now.
Find the replacement USB cable and connector and
remove it from the protective plastic envelope.
While you press the latches (A) in, connect the USB cable and connector to the power switch as shown in Figure 1.
Figure 1. Attaching the USB cable and connector to the
power switch
Insert the USB cable and the power switch and
cable into the system as shown in Figure 2. Be careful to route the cables through to the
system backplane.
Figure 2. Replacing the front USB cable into the system backplane
Replace the top and side screws for the power switch as shown in Figure 3.
Figure 3. Replace the top and side screws
Using the labels, plug the USB cable(A) and the power switch and
cable(B) to the system backplane as shown in Figure 4.
Ensure that the cable latch clip snaps into place on the connectors. Figure 4. Plugging in the cables
Replace the rack installation support on the side of the system as shown in Figure 5.
Figure 5. Replacing the rack installation support
Secure each cable in the retaining clip on the inside wall of the system.
