Learn about the features and specifications for the PCI-X Quad-Channel Ultra320 SCSI RAID Adapter for IBM® System i® models.
For information about using an auxiliary-write cache IOA, see Auxiliary-write cache IOA (FC 0641, 0649, 5582, 5583, 5590; CCIN 574F).
| Item | Description |
| Adapter FRU number | 42R5130 |
| Cache battery FRU number | 39J5554 |
| Cables | Attachment cables are included with the attaching subsystem or device. |
| I/O bus architecture | PCI-X compliant |
| Slot requirement | One available 3.3 volt PCI or PCI-X slot when
the disk controller adapter is used by itself. Two available 3.3 volt PCI or PCI-X slot when the disk controller adapter is used with an auxiliary-write cache adapter. |
| Operating system or partition requirements | IBM i:
AIX
Linux
| Installation Information | For system-specific adapter placement information, see the PCI adapter placement for machine types 82xx and 91xx or the PCI adapter placement for machine type 94xx topic collections. . |
