Learn about the specifications and LEDs for the dual port gigabit
Ethernet-SX PCI-X Adapter.
The dual port gigabit Ethernet-SX PCI-X Adapter is a high-performance,
highly integrated, universal, Ethernet LAN adapter for PCI-X and PCI systems.
The adapter presents one electrical load but appears as two independent devices
to software. The adapter provides 1000 Mbps throughput on a standard shortwave
(850nm) 50/62.5 micron multimode optical cable and conforms to the IEEE 802.3z
standard and supports distances of 260m for 62.5u MMF and 550m for 50.0u MMF.
- 1
- LED
- 2
- Multimode Fiber LC Receptacle
Understanding the adapter LED
The
LED on the Dual Port Gigabit Ethernet-SX PCI-X Adapter provides information
about the card's operation status. The LED is visible through the card's mounting
bracket and, when lit, indicates the following conditions:
| LED |
Status |
Off
On (Green)
Flashing (Green)
No Link/No Activity
Link, No Activity
Link, Activity
Specifications
- Item
- Description
- FRU number
- 03N6973* or 80P6451**
- * Designed to comply
with RoHS requirement.
** Not designed to
comply with the RoHS requirement.
- I/O bus architecture
- PCI 2.2 and PCI-X V1.0a compliant
- Busmaster
- Yes
- Maximum number
- For system-specific
adapter placement information, see the PCI adapter placement for machine types 82xx and 91xx or the PCI adapter placement for machine type 94xx topic collections.
- Adapter size
- PCI short form
- Connector information
- LC fiber optic
- Wrap plug
- LC fiber optic, part number 12R9314
- Cables
- Customer supplied. Optional LC-SC converter cables are available.
- LC-SC 62.5 micron converter cable , part number 12R9322, FC 2459
- LC-SC 50 micron use converter cable, part number 12R9321, FC 2456
If
