Learn about the features of the PCI 2-Line WAN with Modem.
Feature 0614, 0615, 2793, or 2794 is a 2-Line WAN w/Modem that provides one RVX port and one integrated modem port. Port 0 is the modem port and supports V.92 56K Async PPP, V.92 data modem, V.44 data compression, V.34 FAX modem and FAX functions, such as ECM and 2D/1D conversion. Port 0 does not provide Sync modem capabilities (SDLC and Sync PPP). Port 1 is the RVX port and supports multiple communications protocols, including synchronous operations.
ECS is supported from both the modem port and the RVX port.
The adapter does not support the remote ring indicate function.
2793 is the non-CIM (Complex Impedance Matching) version offered in all countries and regions except Australia and New Zealand.
0614 is a direct attach 2793 for Linux.
2794 is the CIM (Complex Impedance Matching) version, which is offered only in Australia and New Zealand.
0615 is a direct attach 2794 for Linux.
6803 is a WAN with modem adapter, which provides connectivity for IBM® Electronic Customer Support (ECS) only. This feature is the non-CIM (Complex Impedance Matching) version offered in all countries and regions except Australia and New Zealand. 6803 is functionally equivalent to 2793, but 6803 indicates to IBM configurator tools that the IOA is being used by the IBM i operating system in an IOPless mode. When in IOPless mode the adapter function is restricted to communicating to IBM ECS on port 0 (modem port). Port 0 supports V.92 56K PPP, V.92 data modem and V.44 data compression. Port 0 does not provide Synchronous modem capabilities (SDLC and Synchronous PPP). Port 1 is the RVX port and is not supported in an IOPless mode.
6804 is a WAN with modem adapter, which provides connectivity for IBM Electronic Customer Support (ECS) only. This feature is the CIM (Complex Impedance Matching) version offered in Australia and New Zealand. 6804 is functionally equivalent to 2794, but 6804 indicates to IBM configurator tools that the IOA is being used by the i operating system in an IOPless mode. When in IOPless mode the adapter function is restricted to communicating to IBM ECS on port 0 (modem port). Port 1 is the RVX port and is not supported in IOPless mode. Port 0 supports V.92 56K PPP, V.92 data modem and V.44 data compression. Port 0 does not provide Synchronous modem capabilities (SDLC and Synchronous PPP).
If
the IBM Prerequisite Web site
