Plug and receptacle types: Model 9116-561
Use the Plug and receptacle type by voltage and amperage table to determine the plugs and receptacles available for your system.
Table 1. Plug and receptacle types by voltage and amperage
Voltage and amperage Plug and receptacle type
250 V, 10 A Type 2, Type 6, Type 19, Type 24, Type 25, Type 32, Type 62
250 V, 15 A Type 5, Type 10
250 V, 16 A Type 18, Type 22, Type 25, Type 32
250 V, 13 A Type 23
200-240 V, 10 A Type 26, Type 66, Type 69, Type 73, Type 76
200-240 V, 12 A Type 57
To determine the plug and receptacle type your model will need, follow these steps:
  1. In the preceding table, find the Voltage and Amperage of your power supply.
    The Plug and receptacle type that is listed in the same row as your voltage and amperage supports your model.
  2. Click on the plug and receptacle Type to view information about that type.
If more than one plug appears in your row:
  1. Click one of the plug and receptacle types.
  2. In the Plug and Receptacles table, look for your country or region (the country or region where your model will reside) in the Countries or regions column (on the right side of the table).
  3. Repeat steps 1 and 2 until you find your country or region in the Plug and Receptacle table.
    The plug and receptacle type that lists your country or region is the type for which you need to plan.
Note: If your country or region is not listed or, for some reason, you still cannot determine your plug and receptacle type, contact your sales representative.
Last updated: Tue, June 17, 2014
