Model 9406-840 and SB3 server specifications
Server specifications provide detailed information for your server, including dimensions, electrical, power, temperature, environment, and service clearances.
Use the following specifications to plan for your server.
Model 9406-840 or model SB3 with the 9079 I/O expansion unit
The 5074 expansion unit, 5078 expansion unit, 8079 optional 1.8 m model 9406-840 I/O rack or 5079 1.8 m expansion unit are available with model 9406-840 or model SB3 servers.
Table 1. Dimensions
Measurements Maximum configuration weight Width Depth Height
Metric 397 kg 565 mm 1320 mm 1577 mm
English 875 lb 22.3 in. 52.0 in. 62.0 in.
Table 2. Electrical
Electrical Properties
kVA (maximum)  2.526
Rated voltage and frequency3 200-240 V ac at 50-60 plus or minus 0.5 Hz
Thermal output (maximum) 8191 Btu/hr
Power requirements (maximum) 2400 W
Power factor 0.95
Inrush current 100 A
Leakage current (maximum) 3.5 mA
Phase 1
Table 3. Temperature requirements
Operating  Nonoperating
10 - 38°C (50 - 100.4°F) 1 - 60°C (33.8 - 140°F)
Table 4. Environment requirements
Noncondensing humidity  8 - 80%  8 - 80%
Wet bulb temperature 22.8°C (73°F) 27°C (80.6°F)
Maximum altitude  3048 m (10000 ft)
Table 5. Noise emissions1
  Operating Idle
LWAd (Category 2D, General business) 7.0 bels 6.9 bels
LpAm (1-meter bystander) 51 dB 51 dB
Table 6. Service clearances
Front Back Sides2 Top2
762 mm 762 mm 762 mm 762 mm
30 in. 30 in. 30 in. 30 in.
Table 7. Notes
Notes:
  1. For a description of noise emission values, see Acoustics.
  2. Side and top clearances are optional when operating
  3. The power supplies automatically accept any voltage with the published rated voltage range. If dual power supplies are installed and operating, the power supplies draw approximately equal current from the utility (mains) and provide approximately equal current to the load.
Last updated: Tue, June 17, 2014
