Model 9406-830 and SB2 server specifications
Server specifications provide detailed information for your server, including dimensions, electrical, power, temperature, environment, and service clearances.
Use the following specifications to plan for your server.
9406-830/SB2 including the 9074 I/O enclosure
The 5074, 5078, or 5079 PCI expansion unit is available with model 9406-830 or model SB2.
Table 1. Dimensions
Measurements Width Depth Height Maximum configuration weight
Metric 483 mm 1080 mm 1270 mm 400 kg
English 19.0 in. 42.5 in. 50.0 in. 881.5 lb
Table 2. Electrical
Electrical characteristics Property
kVA (maximum) 1.684
Rated voltage and frequency3 200-240 V ac at 50-60 plus or minus 0.5 Hz
Thermal output (maximum) 5461 Btu/hr
Power requirements (maximum) 1600 W
Power factor 0.95
Inrush current 80 A
Leakage current (maximum) 3.5 mA
Phase 1
Table 3. Temperature requirements
Operating Nonoperating
10 - 38°C (50 - 100.4°F) 1 - 60°C (33.8 - 140°F)
Table 4. Environment requirements
Property Operating Nonoperating
Noncondensing humidity 8 - 80% 8 - 80%
Wet bulb temperature 22.8°C (73°F) 27°C (80.6°F)
Maximum altitude 3048 m (10 000 ft)
Table 5. Noise emissions
Property Operating Idle
LWAd (Category 2D, General busness) 6.7 bels 6.7 bels
LpAm (1-meter bystander) 50 dB 49 dB
For a description of noise emission values, see Acoustics.
Table 6. Service clearances
Front Back Sides1 Top1
762 mm 762 mm 762 mm 762 mm
30 in. 30 in. 30 in. 30 in.
1Side and top clearances are optional when operating.
Table 7. Notes
Note: The power supplies automatically accept any voltage with the published rated voltage range. If dual power supplies are installed and operating, the power supplies draw approximately equal current from the utility (mains) and provide approximately equal current to the load.
Last updated: Tue, June 17, 2014
