This function displays the temperature on the 7037-A50 server and the 7047-185 workstation.
This function is available in both normal and manual operating mode.
The display alternates every two seconds between ambient, CPU1, and CPU2 temperature.
The following table provides details about this function.
| Function/Data | Action or description |
1 0 _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ |
Use the Increment or Decrement buttons to scroll to function 10. |
A m b i e n t : 3 e , 3 e _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ |
Press Enter to start function 10. The ambient
temperature is listed in hexadecimal (degrees Celsius).
C P U 1 : 5 0 , 6 f _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ |
Press Enter to start function 10. The CPU1
C P U 2 : 0 , 0 _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ |
Press Enter to start function 10. The CPU2
Use the Increment or Decrement buttons to scroll through the control panel functions. |
