You can use the Integrated Virtualization Manager to
create a new system plan based on an existing system configuration.
The Integrated Virtualization Manager management
partition reads the configuration information on the managed system and stores
this information in the system plan.
To create a system plan based on an existing system configuration
from the Integrated Virtualization Manager, complete
the following steps:
- From the navigation area, select Manage System Plans. The Managed System Plans page opens.
- Click Create/Import system plan from the
toolbar at the top of the System Plans table. The Create/Import
System Plan page opens.
- Select the Create option.
- Enter a System plan file name and plan description for the new
system plan.
- Click OK. The Integrated Virtualization Manager generates
a new system plan based on the current system configuration.
Now that you have a new system plan, you can export the system plan,
import it onto another managed system, and deploy the system plan to the managed
system.
Note: As an alternative to the Integrated Virtualization Manager Web
user interface, you can also use the mksysplan command
to accomplish this task.
