Find information and procedures for troubleshooting the client partitions.
If your client partition is using virtual I/O resources, check the Service Focal Point and Virtual I/O Server first to ensure that the problem is not on the server.
On client partitions running the current level of AIX®, when a hardware error is logged on the server and a corresponding error is logged on the client partition, the Virtual I/O Server provides a correlation error message in the error report.
errpt -aRunning the errpt command returns results similar to the following:
LABEL: VSCSI_ERR2
IDENTIFIER: 857033C6
Date/Time: Tue Feb 15 09:18:11 2005
Sequence Number: 50
Machine Id: 00C25EEE4C00
Node Id: vio_client53A
Class: S
Type: TEMP
Resource Name: vscsi2
Description
Underlying transport error
Probable Causes
PROCESSOR
Failure Causes
PROCESSOR
Recommended Actions
PERFORM PROBLEM DETERMINATION PROCEDURES
Detail Data
Error Log Type
01
Reserve
00
Error Number
0006
RC
0000 0002
VSCSI Pointer
Compare the LABEL, IDENTIFIER, and Error Number values from your error report to the values in the following table to help identify the problem and determine a resolution:
| Label | Identifier | Error Number | Problem | Resolution |
| VSCSI_ERR2 | 857033C6 | 0006 |
The Virtual SCSI server adapter on the Virtual I/O Server partition is not open. | Make the server adapter on the Virtual I/O Server partition available for use. |
| 001C |
The Virtual SCSI server adapter on the Virtual I/O Server partition has been closed abruptly. | Determine why the server adapter in the Virtual I/O Server partition was closed. | ||
| VSCSI_ERR3 | ED995F18 | 000D |
The Virtual SCSI server adapter on the Virtual I/O Server partition is being used by another client. | Terminate the client partition that is using the server adapter. |
| 000D |
The Virtual SCSI server adapter (partition number and slot number) specified in the client adapter definition does not exist. | On the HMC, correct the client adapter definition to associate it with a valid server adapter. |
