You might need to replace a Small Computer System Interface (SCSI) disk drive
in a system or expansion unit while the Linux® operating
system or logical partition that controls the disk drive location is powered
on. Use the procedure in this section to perform this task.
Attention: Read
these instructions carefully and understand the complexity of the powered-on
procedure before you begin. If the system or logical partition that controls
the disk drive you are replacing is at the Linux command
line, you can use this powered-on procedure.
Go to Replace a disk drive with the system or logical partition powered off,
if:
- You are installing a disk drive in a 5791, 5794, or 7040-61D expansion
unit
- You are installing a disk drive that will be connected with the 6203 or
6204 SCSI adapter
- You do not feel comfortable using the powered-on procedure
Note: Some of the figures in these procedures might not look exactly
like the system or expansion unit that you have. However, the steps to perform
the task are the same.
Prepare the system
- Perform prerequisite tasks as described in Before you begin.
- Is the disk drive you are replacing in a redundant array of independent
disk (RAID) 0 array or is the disk drive you are replacing in a failed RAID
level 5 or 10 array?
- If the disk drive you are replacing is in a redundant array of
independent disk (RAID) Level 0 disk array or in a failed RAID Level 5 or
RAID Level 10 disk array, you must delete the disk array before replacing
the disk. For instructions, see the PCI-X SCSI RAID Controller
Reference Guide for Linux.
This guide is available from the SCSI PCI Adapters Web page at http://publib.boulder.ibm.com/infocenter/pseries/v5r3/index.jsp?topic=/com.ibm.pseries.doc/hardware_docs/scsipciadapters.htm.
- Remove the system unit door or expansion unit door or open the
rack front door. For instructions, select the appropriate procedure
from the following list:
- Remove the front cover. For instructions on removing
the cover, select the appropriate procedure from the following list:
To replace a disk drive in a location with the Linux system
or logical partition that controls the disk drive location powered on, select
