Install a disk drive with the Linux system or logical partition powered on
You might need to install a Small Computer System Interface (SCSI) disk drive in a system or expansion unit while the Linux® operating system or logical partition that controls the disk drive location is powered on. Use the procedure in this section to perform this task.
Attention: Be sure you read these instructions carefully and understand the complexity of the powered-on procedure before you begin.
If any of the following steps apply to you, go to Install a disk drive with the system or logical partition powered off.
Note: Some of the figures in these procedures might not look exactly like the system or expansion unit that you have. However, the steps to perform the task are the same.
Prepare the system
  1. Perform prerequisite tasks as described in Before you begin.
  2. Remove the system unit door, expansion unit door, or the rack door. For instructions, select the appropriate procedure from the following list:
  3. Remove the front cover. For instructions on removing the cover, select the appropriate procedure from the following list:
  4. Look at the front of the system or expansion unit and determine the next available disk drive position. For information, see Disk drive locations.
    Note: When you have a system with an expansion unit, fill the slot positions in the system unit first. However, you can choose a different disk drive placement depending on your data protection strategy.
  5. Record the position where the new disk drive will be installed. For example, the next available disk drive position might be P3-D4.
Install a SCSI disk drive in a system or expansion unit using Linux kernel 2.4 or Linux kernel 2.6.
